Windows 7 - Which do I need?
26 Mar 2006
United Kingdom
Which windows 7 do I need? I have Vista and want a fresh install to 64bit. Which copy do I get, upgrade or full?
Thanks in advance.
It is up to you. Personally I would try and get the full Retail copy - since it gives you the freedom to install it anywhere, whenever you want.
The Upgrade is great if you want to save money, and don't plan to install it elsewhere in the future.
So the upgrade does allow me to do a fresh install to 64bit over my 32bit vista? I'm only planning to install it on my laptop.
Yep you can do a clean install with the Upgrade media. All it needs it to detect a previous version of Windows.
