My MX-5 Supercharging Project
28 Feb 2007
Hi all,
Thought I would share with you all my project to supercharge my 1991 MX-5 as it is now finished :cool:
Basically, the project was to build my own Megasquirt replacement/standalone ECU then build a kit based around the BMW mini cooper S M45 supercharger.
This has been pioneered by someone on one of the MX5 forums I visit, here is his build log:
http://www.mx5nutz.com/forum/index.php?showtopic=42329
Setup as it stands:
DIY Megasquirt 1 V3.0 standalone ECU (built this and had it running for 6 months NA - the only way to go IMO)
RX-8 425cc injectors (these are plug and play)
Eaton M45 supercharger with standard pulley
1.8 clutch and flywheel fitted
LC-1 WB O2 sensor with gauge in eyeball air vent
Front mounted intercooler
I'll just let the pictures do the talking........
This is the Megasquirt (MS1 V3.0) which took me many many hours to turn from a bare board into this. You build the basic kit with customisations to match specific engine configurations (to read sensors, control idle valve etc etc), luckily the B6 engine is a pretty simple engine.
This is the wiring loom connecting the MS to the stock wiring harness. The only modification to the stock harness was to disconnect the NB O2 sensor (I installed an LC-1 wideband with gauge) and to remove the AFM and connect up a GM IAT sensor in its place. The purple wire was disconnected as this was for the LC-1.
As this is such a big step (removing stock ECU and replacing with this) I decided to do this with the car still naturally aspirated and to run with it in this state for quite a while to iron out any problems and get my head around tuning it. I actually did a couple of track days like this, here is a video from one: http://www.youtube.com/watch?v=Cgxc_UIzEvk
and this is what the engine bay looked like at the time, the LC-1 wideband O2 sensor and gauge was fitted at this point too to help me tune the fuelling, for the spark map I defaulted to a basemap for this particular car and built some det cans to make sure the engine wasnt pinking. The exhaust manifold also had to be heat wrapped to create clearance for the supercharger.
I ran it like that for about 6 months whilst building the supercharger kit, the Eaton supercharger required a few modifications to be able to use it - the inlet had to be sawn off as did a bit near the pulley and tapped holes had to be made in the inlet for me to mount my inlet track (plus second throttle body) on.
These are some of the basic components, I managed to get someone at my previous place of work to do the welding for me for some beers which was handy :)
Yellow injectors are the RX-8 ones.
This is what it looked like when it all came together - note this was before I fitted the intercooler and havnt got any pictures of after it is fitted :rolleyes:
http://img3.imageshack.us/img3/1187/dscf1348i.jpg
A little video of it idling:
http://www.youtube.com/watch?v=Jcks7vUuod4
I expect the engine is now producing somewhere in the region of 170-190BHP, others have had similar setups tuned on a rolling road with smaller supercharger pulley get 220BHP.
Looking forward to getting this on track :D
Very nice mate, how much did the conversion cost you in total?
I'm sure Howard will be in at some point to compare notes ;)
Very nice, been wanting to get my 5 charged since I bought it in November. How much was the MS? I might build one whilst I'm banned and run it N/A when i'm back on the road.
MSDIY are about £200 iirc, or a 2nd hand pre built one is around £250.
I bought the kit from DIYautotune, it cost $300 in total which works out as £190, this is what I bought:
1. 1 x PCBv3 -- PWM IAC Valve Control (TIP120) 'Mod-Kit'
2. 1 x Lead Bending Tool
3. 1 x MegaSquirt-I Programmable EFI System PCB3.0 - UnAssembled Kit
4. 1 x PCBv3 and v2.2 -- Relay Control 'ModKit' (VTEC, TVIS, Fans
5. 1 x MSPNP and DIYPNP IAT Sensor Kit - Steel Bung
6. 1 x MegaSquirt Wiring Bundle - 23" Long
7. 1 x PCBv3 and v2.2 -- Pullup Resistors 'ModKit'
8. 1 x MegaSquirt Tuning Cable (DB9 Straight Thru)
If you are confident with a soldering Iron, have got a basic grasp of electronics and like saving money then the DIY kit is for you.
Even If I had bought the plug and play kit I still would have had to modify the PCB to control the idle valve and to do the improved spark output modification.
Running it NA for a while is the only way to go IMO, you WILL spend HOURS scratching your head using the software (I use Tunerstudio) and getting your engine to perform as it did stock (cold starts, acceleration enrichment, afterstart enrichment, fuel tuning, idle valve tuning etc etc). Its best to get all this out of the way and learn it all properly before adding forced induction where if you are not careful you really can break things :eek:
In terms of total costs, I probably spent 1.5-2K.
MS - £200
LC-1 WBO2 - £160
M45 - £200
Engine bracket + strut - £50
Tensioner + pulleys + belt - £100
Inlet (cost of pipe) - £20
Outlet (cost of pipe) - £15
Bypass + pipe - £100
2nd throttle body - £25
RX-8 425cc injectors - £160
Intercooler kit - £250
Heat wrap - £20
Bigger clutch - £300 (got Autolink to supply & fit)
Odds and ends probably add up to atleast £100, so thats £1700.
Too many man hours to mention, I started this project in November last year (before you were supercharged howard? :p )
Just get a room then you can stroke each others 6inch GHDs together.
Top stuff, car projets rock! :D
Wow that was fast work, seems like only last week I was nosing around your engine bay. I'm very impressed with the ecu, did not know you also had to build it. :eek:
Right, stud conversion, stronger head gasket and small pulley, go go go. :D
who's had 220 bhp out of an M45? Didn't think you could get much more than 210 due to the supercharger being too small, you really need an M62 for that sort of power?
Perhaps a stupid question, but why do people seem to opt for a custom supercharger setup rather than a off the shelf turbo kit?
Cost wise they don't look massively dissimilar on the face of things.
Maybe people want the smooth power delivery a SC gives you? A turbo just dumps all the power in one blob.
A properly turbo'ed MX5 is fantastic though, very little lag if any (depending on the power an the size of the turbo of course).
Personally I prefer the driving characteristics of a turbo, I tried both s/c and turbo mx5 before deciding the turbo route. Still 236bhp and a 0-60 time of just about 5s (I remember taking Conanius out in it - he couldn't believe it! :D) was more than acceptable to me!
I REALLY want one again though :(
