Single computer multiplayer games
22 Oct 2005
Moving...
I've got an xbox 360 (wired) which I use for a couple of games on the PC. I was thinking of buying another one so I could play mates at some multiplayer games but I wasn't sure if many games will support multiplayer on a single computer.
I've got Fifa 09, nba 2k9 and virtua tennis 09 which work if one uses a keyboard and the other uses the controller, but this isn't ideal for my setup.
So, my questions are;
- Do any games support multiple controllers? (Using XP if that makes a difference)
- And if so, anyone know any non-sports games that work by split screen?Mainly looking at driving games but if any FPS work that might be worth a go.
Or is it restricted to sports games as then you have no need for a split screen?
Thanks for any help.
