Why ?
Rover K series engine, even more prone to eating headgaskets in freelanders than in the 200.
Why ?
Why ?
Providing you have the later models ( k series ) with the better gaskets and remote thermostat they are a lot more reliable.
My wife has a 2003 model 1.8 which we have had for the last 4 years, the only thing apart from oil/filter that I have done to it is front pads, water pump/cam belt, clutch master cylinder as it was becoming sticky ( its a sealed system £50 for master and slave which took 30 minutes to fit ) and tyres.
He wont get a td4 either
lol. Fair point thoughSubaru Justy?
the car that isnt afraid to tell it like it is.
Agreed on the Legacy, but for a Justy I think he'd be all right[FnG]magnolia;17510574 said:Be careful of any Subarus you might be looking at which are at or around the big service interval. That's a biggie and can take a considerable amount of your budget due to replacing cambelt, waterpump, all fluids, filters etc etc.
I don't think you'll get a (good) Legacy for 2 grand that also has decent tyres but you might get a Forester.
So, here's the brief:
£2k max
4WD
Comfy/well-spec'd
Not stupid on fuel but not the biggest concern.
Manual if possible
Not asking much I know!
Mitsubishi GTO VR4, meets all your requirements and has 300bhp![]()
