- 21 May 2010
Just wondering if the 768mb 460 would be fine for gaming at the above resolution or if it would be worth the extra 40+ for the 1gb version?
Really cannot see that a 1GB 460 is worth the extra cost versus a 768MB 460.
I defy anyone to discern the difference without using benchmarking progs.
See - http://www.anandtech.com/bench/Product/156?vs=180
Cheers,
vfm
I'm interested in this, where do you get reliable information on VRAM usage? For example, I know it's hard to break 1GB VRAM even with Crysis but it can been done at 2560 x 1600.
I game at 1920 x 1200 so will that res ever exceed 1GB VRAM, in any game over the next year or two even? If so do I need a card with 2GB VRAM?
'A 8800gtx/9800gtx/gtx250 would be good enough for your current resolution'
But dont give the added advantages of the newer tech, ie, lower power, heat, noise, not to mention higher fps and DX11.![]()
..but can be had for £40 second hand. DX11 and higher FPS isn't that much of a deal breaker when the price difference is £120![]()
You ought to be planning a monitor upgrade really. If you are in the near future, get the best GPU you can afford. Games aren't going to get any less damanding on the hardware. If you are going to stick with that monitor for the forseeable future you really dont need much GPU so keep your pennies and pick up something cheap.
