- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
that makes sense then.
Still a nifty piece of kit. Although the qnap does the same, they will probably cost a similar ammount and do a similar ammount. So comes down to personal preference
which one did you get by the way ?
I got the Drobo FS (the latest one).
The first one is plain Drobo (USB 2.0), then there was Drobo S (Firewire 800 & USB 2.0). The plain one has 4 Bays, Drobo S has 5 bays. These 2 can be use on a LAN with the Droboshare (separate piece of hardware) or through something like the Apple Extreme/Time Capsule.
The Drobo FS is Gigabit LAN only, not USB or Firewire, but it has 5 Bays, and it is faster than the previous versions..allegedly. It can be use on LAN without the droboshare, and actually they are phasing that out since it wasn't the most stable of hardware from user reviews, plus it was slow.
