...7 hours of lectures a day...
Best you can hope to do is write things down. It keeps you occupied.
Fellas = korean ginseng, ladies = siberian ginseng (though not a true ginseng).
Do you find 6 - 7 hours enough? Fair enough if you do. Try aiming for 7.5.
Skip one of the lectures you're comfortable with and have a power nap.
7 lectures a day?! Really?
Getting up between lectures and getting some fresh air might help - lots of people in dark room for extended periods of time and the CO2 rises and everyone gets lethargic.
Try going to bed one hour earlier and see how that works out for you.
Hold the clamp open, stick your todger in. Guaranteed to keep you awake!
What are you going to do when you go to work?
Drink more water.
True story.
Pro-Plus, and lots of it.
Routine mate.
Get into bed at 11:30pm minimum and doss about in bed with either listening to music or reading a book. Then wake up at the exact time every day, as in set your alarm for 8:00am and jump out of bed as soon as the alarm goes off.
Do that for a week and you'll be wide awake before that alarm goes off. All it takes is a week but most don't have the muster to keep to a simple routine (even for a week).
That should give you good rest, anything more than 8 hours and you'll start to get lethargic and feel like you need even more sleep.
Taking a bottle of water to class helps a ton too.
I begrudge the idea of spending almost half my day in bed, not that it will make much difference anyway, it'll still take me a couple of hours to get to sleep. Unfortunately I'm not one of those people that can just sleep anywhere at any time.
Adderall?
