Simple question (I hope).
We have loads of Cisco GLC-LH-SM SFP's and normally we run in our own fibres (we do networking for big events so things are temporary) however in a couple of weeks we have a job in a venue where we will be using their internal structured fibre links between floors.
I've been told by their network folks that this is spangly new OM3 MM fibre.
Our SFP's are supposed to be able to work over SM and MM fibre, and I know that when they are being used on OM1/2 you are meant to use a mode conditioning cable (though the costs I've seen these cables sold for I would be inclined to just buy new MM modules).
Cisco's documentation is quite clear on this, what its a bit confusing on though is that it states with regards to OM3 fibre:
"MCP is required for 1000BASE-LX/LH applications over FDDI-grade, OM1, and OM2 fiber types. MCP should never be used for applications over OM3, also known as "laser-optimized fiber."
Now I understand why on OM1/2 you need it because of the way the LED light is spread across the fibre core, but I'm not sure of the way OM3 works.
Simply put will our SFP modules with MM OM3 fibre running between them magically *just work* or will it not work at all ?
