Ah, lower-case Helvetica, tightly tracked in either black or white with a vibrant key colour. The designer's "I Win" button![]()
You could at least kern it properly for the poor fellow![]()
BTW, there already is a WatchRepairUK.com, unless that's your site.
http://watchrepairuk.com/
WatchRepairsUK.co.uk is a bit too have the UK part in it? Personally, I think they look better without.
Two quick ideas.
Why change what works?![]()
Where did you lift the images from?
Which images? On the site mockup? Both images used are high-res from different sources.
I should point out to the OP that the site mockup only serves the purpose of showing the logo 'in action'.
You didn't design the new Gap logo did you?Ah, lower-case Helvetica, tightly tracked in either black or white with a vibrant key colour. The designer's "I Win" button![]()
