Putting together a rig mainly for the wife's Photoshop work, but I'll be using it for some gaming - I don't play a huge amount of games anymore but want something that won't be too weak. It will be used with a 23" Samsung widescreen monitor/TV (1366x768) and also must have dual DVI out as the missus would like to move to a dual monitor setup in the future.
I was thinking maybe a HD 4850 - but would that be overkill for the resolution I'll be using? I'm working to a tight budget, so if a lesser card would work just as well I can spend the money elsewhere in the system.
CPU will be a X4 965 BE I've picked up off a friend. I would prefer ATi, but am open to suggestions if there's something brilliant from nVidia that would fit the bill.
Thanks
ps. I'm a bit out of touch with hardware as I haven't built anything for a couple of years
Thanks
