- 6 Dec 2004
- Scotland
Having tried various things I am still in need of assistance to try to overclocked my Q6600 which is currently running at stock 2.4 GHz. Below is a picture of the BIOS screen used for treating various settings for overclocking. I have tried changing the CPU host frequency and allowing the board to control voltage that the only result is that the BIOS resets itself after it failed to load. I've also tried using the CIA2 which does a sort of overclocking which works on the basis of upping the frequency when there is a bigger load and dropping back when there is not. This sometimes works well from some programs refuse to run at all which is annoying.
What am I doing wrong or is that something that I've forgotten because it seems most people can persuade this process up to 3 GHz? My machine details, as recorded by CPU -- Z are as the link below. I suspect that my RAM is not good enough for the overclocked as it is PC 6500 but will be grateful for some advice please.
http://valid.canardpc.com/show_oc.php?id=1424045
