The Build :)
16 Jul 2010
Reading
Parts finally arrived so spent my night building my new machine ^_^
Full Inside View
Heat sink
Full view
This is my first computer I have build using a case with Cable Management. Behind the panel it's a bit messy (And by a "Bit" I mean its a "LOT"^^)
Spec:
Argon Extreme Intel Core i3 2.93GHz @ 4.20GHz Overclocked Bundle
MSI GeForce GTX 460 Cyclone 768MB GDDR5 PCI-Express Graphics Card
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply
2x Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin
Coolermaster CM-690 II Lite Dominator Case - Black
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
Samsung SH-B083L/RSBP 8x BluRay ROM / 16x DVD±RW Drive - Black (Retail)
Booted up first time, no problems ^_^
/Johnathan
/Johnathan
Nice Build :)
Is the fan on the cpu cooler sucking air through the heat sink? I would personally move it around so it was blowing air through the heatsink and out the exhaust. Should give better temps.
EDIT: Beaten to it lol
I decided to put the PSU in that way. It doesn't show to logo BUT, the 4Ping CPU cable is short and if I put it in the other way it wouldn't fit around the back (It barely does that way). That and other fixed power cables (As you can see) are pretty short :|
Nice Build :)
And yes, I was thinking of turning the heat sink around the other way. Will do it later ^^
/Johnathan
/Johnathan
Not the PSU the CPU cooler is the wrong way :)
Hope you enjoy it, that GPU is very good btw.
Idles at 40% which I find quite high, considering it doesn't go beyond 40% when playing some games due to my modified fan settings. (temps are pretty cool too)
Even running furmark/ffxiv/kombuster it won't go beyond 53% (80C max)
Good tidy job there. :D
How quiet/loud are you finding the operating noise level with the samsung blu-ray drive ?
I don't know. It is pretty much the same as any other disk drive I've owned. HOWEVER, there is a REALLY high pitched squeeking or buzzing noise which only I can seem to hear coming from it when it's max speed. Must be really high pitch if only I can pick it up, but it makes my teeth hurt :(
Lucky I don't use my disk drive much :)
/Johnathan
I can +1 that case as well as I have one.
Like you say, OP, it will no doubt be a massive mess of wires and cables behind that motherboard tray, but that is what it is there for. :D
