Akasa 4002HP Venom vs coolIT A.L.C
19 Jul 2007
notts , uk
i am running the Akasa 4002HP Venom with 2x venom fans (push/pull) , msx temps it hits at stock speeds on my phenom II 955BE is 52c full load with a room temp of 25c , but running with 2 fans on the venom makes my system noisey under load (case fitted with 4x Scythe Kaze Jyuni 1200RPM Slipstream fans ) . will the coolIT A.L.C be worth replacing the venom cooler ? , was also thinking about overclocking my phenom 955 so would it be worth it ?
Would be a waste of money imo mate, those kits are poor at best see the other threads on here. How about modding the current fans to 7v see what temps you get
IMO it's the slipstreams which are making the noise
when I took them off my build it was so much quieter than before
