out of the loop, what's a quiet upgrade for an 8800GT?
  • Thread starter Thread starter dod
  • Start date Start date
dod
dod
31 Oct 2002
Inverness
As it says, I'm doing an upgrade and considering changing the graphics as well, although to be honest it's more of a want to than need to. Last game I bought was HL2 and it still copes fine with that :o
Doesn't need to be top of the range but it must be quiet, preferably within £250.
Edit: Oh, and preferably single slot, if you still get such a card :p
best I can think of which is quiet and single slot is one of the new powercolor 5770's although this is only a ~£100 card
however the Gainward GTX 470 which comes with an aftermarket cooler might be worth looking in to for £235
I'm buying a new card in the not too distant future so have a scout round of the members market for a nice, cool and quiet 4870x2. :D
Sorry, couldn't resist. :) Though mine isn't as hot or noisey as some others out there. :p
I would say wait for the 6000 series from AMD which isn't far off at all. A 5770 single slot will be an upgrade but I don't think it will be a particularly substantial one. Someone correct me on that if need be.
as above, if your mobo supports it you could maybe xfire a couple of 5770s or if it doesnt then to get a decent upgrade youre prob gonna have to look at dbl slot cards
@Arc
That was about right.
@Op
I would get a dual slot TBH, as IMO the single slot coolers are not substantial enough for performance cards, which means more noise.
Another option is something like a Gigabyte GTX460, but as already said, it's better to wait just at the moment.
You just need to wait I mean the 6series from ATI/AMD are coming, the price drops will be worth the wait and a 8800gt will no doubt get you by for a few weeks.
Note: I hate saying wait, when the 6 series comes out then you should wait again for nvidias answer, but then..more waiting as the 6 series derivatives will drop the price even more.
Personally I would get a Gigabyte HD 5770 Silent, less than £140 and a worthy upgrade, though expensive for a 5770 (equal (ish) to a 4870) its silent solution is class leading (cooling vs noise)
MSI Hawk 460 is quiet and reviews have been good ...one of the best cards on market...
Only issue is its dual slot, but boy it has decent cooling.
Check out this vid.
Cheers
Von
It's generally a bad idea to get two midrange cards when a single high end card is an option.
I agree, I was just giving the option as I did not know why the OP had specified single slot, if its an actual space restriction rather than a preference then this might not be an option
