Taken on my week on the Hawaiian island of Maui last week. I spent the whole week trying to get a decent shot of this but cloud cover kept me at bay right up until the final night, when I managed to get the kind of shot I was after, which was one including some foreground interest. In this instance it was the shoreline with the waves crashing on the rocks, which I painted over with a torch during the exposure.
I also did a write up on my blog about my efforts to photograph the Milky Way, along with more images, including one taken in total darkness with the D3s, hand held for 2 seconds at ISO 102,400 - crazy stuff.
Check it out here.
D3, 14-24, F2.8, ISO 6400, 30 seconds
I am so impressed with this. Can i ask you a quick question, is it possible for me to take decent astro photographs with a lumix fz 18? and is it simply extending the shutter speed between 30-secs to a minute?
Max resolution 3264 x 2448
Click for helpLow resolution 2560 x 1920, 2048 x 2536, 1600 x 1200, 1280 x 960, 640 x 480
Click for helpImage ratio w:h 4:3, 3:2, 16:9
Click for helpEffective pixels 8.0 million
Click for helpSensor photo detectors 8.3 million
Click for helpSensor size 1/2.5 " (5.75 x 4.31 mm, 0.24 cm²)
Click for helpPixel density 32 MP/cm²
Click for helpSensor type CCD
Click for helpSensor manufacturer Matsu****a
Click for helpISO rating Auto, 100, 200, 400, 800, 1250, (6400 high mode)
Click for helpZoom wide (W) 28 mm
Click for helpZoom tele (T) 504 mm (18 x)
Click for helpDigital zoom Yes, 4 x
Click for helpImage stabilization Yes, Lens
Click for helpAuto Focus TTL
Click for helpManual Focus Yes
Click for helpNormal focus range 30 cm
Click for helpMacro focus range 1 cm
Click for helpWhite balance override 4 positions, plus manual
Click for helpAperture range F2.8 - F3.1
Click for helpMin shutter 60 sec
Click for helpMax shutter 1/2000 sec
Built-in Flash Yes, pop-up
Flash range 6 m
External flash No
Flash modes Auto, Red-Eye Auto, On, Red-Eye On, Red-Eye Slow Sync, Off, Slow Sync (1&2)
Click for helpExposure compensation -2 to +2 EV in 0.3 EV steps
Click for helpMetering Multi-segment, Center-weighted, Spot
Click for helpAperture priority Yes
Click for helpShutter priority Yes
Click for helpFocal length multiplier
Lens thread Yes
Click for helpContinuous Drive Yes, 3/2 fps, max 7 images
Movie Clips Yes, 848 x 480, 640 x 480, 320 x 240 @ 30/10 fps
Remote control No
Self-timer Yes, 2 or 10 sec
Click for helpTimelapse recording No
Orientation sensor No
Click for helpStorage types SD/MMC/SDHC card, Internal
Click for helpStorage included 27 MB Internal
Click for helpUncompressed format Yes, RAW
Click for helpQuality Levels Fine, Standard
Click for helpViewfinder Electronic
Click for helpLCD 2.5 "
Click for helpLCD Dots 207,000
Click for helpLive View No
Click for helpUSB USB 2.0 (480Mbit/sec)
Click for helpHDMI No
Click for helpWireless No
Click for helpGPS No
