best iphone 3gs option
You'd be mad to get a new 3gs on contract. Vastly overpriced and designed to make you spend that bit more to get the iphone 4.
Quidco and mobiles.co.uk will get you £100 cashback on the ip4 making the 16gb model roughly the same price.
Also it wouldn't be Overclockers without someone suggesting a quality cheap alternative. Check out the £99 orange san fransisco, that's as good as the 3gs (better screen, slightly worse build quality)
Do they offer the £100 cashback on Orange upgrades? I think I can upgrade my contract next month.
I was looking at tariffs earlier and for an iPhone 4 it's 35 p/m for 18mnths, 300 mins, unlimited SMS, 500mb Data and the phone for 169. However last I checked there was 90 pound cashback from quidco for voda. So it works out well.
the cashback is a nice incentive! But i believe the iphone 3gs is the best bang for my buck unless one of you can suggest a better alternative
3gs... Best bang for buck? :confused:
Sorry, but I can't think of a more overpriced phone you can buy right now (unless your thinking secondhand?)
3gs is possibly the worst bang for buck phone out there right now other than some kind of gold plated monstrosity. like someone said it is only there and priced so high to make people buy the iphone4
for the same price there is a handful of android phones that slaughter it hardware wise and are equal software wise
the resolution is what would put me off most.
So if i went for any android alternative what would be your suggestions>?:)
