Hi guys,
I've whinged and I've moaned about my awful internet on here for years, and you've all tried and tried to help me sort it out. So I thought I'd share with you some good news.
As you'll be aware I've been with Plusnet for years, syncing at between 1 and 1.5mbit depending on how much I tweak my router. I could get 1mbit with standard settings of 1.5mbit if I turned the SNR ratio on my DG834GT down to 1%. My upload was 448kb.
Well, today my O2 LLU package was activated and amazingly, at default settings, I immediatly synced at the following rates. How is this even possible? It's brilliant. The internet is.. actually useable. Everything is literally twice as quick - downloading files at 240kb/s instead of my previous 120kb/s record!
My line stats are now:
Now, I get the impression there is no training period on LLU so I can start fiddling right away. With the noise margin as it is, is it worth trying the SNR ratio trick like I used to use with PN? With it set to 1% as it was with PN, I get a staggering 3.4mbit
ADSL Link Downstream Upstream
Connection Speed 2406 kbps 772 kbps
Line Attenuation 69.5 db 38.6 db
Noise Margin 6.5 db 5.8 db
 ![[TW]Fox](/data/man-of-honor/2009.png)
