Last night my Sony Vaio was acting up whilst I was watching a film. I was getting pritty ****** off with it to the point it froze. I gave it a few smacks and restarted it. It rebooted and worked fine after this 2-3 times.
I get back from work & the gym today to find that it 'can't recover from hibernation'.
I can get into the bios. It seems to take forever to load the recovery partition and then just seems to be stuck at a green background with the cursor. I have recovery disks I made which also do the same thing.
I have my older 120gb harddrive which I just put in and it boots totally fine. I've popped the 500gb back in. It's now booting but taking ages to reach the scrolling green bar just before login. And appears to have been loading now for about 4-5 minutes.
Anybody encountered this before? I've found lots of fixes online but in order to do these I have to be logged in, which I can't do!
Any help would be greatly appreciated!
Thanks
BennyC
Edit: When accessing the recovery partition via F10 I get:
Then I can either enter or escape. Entering loads a black screen, then the windows bar scrolls. Then black screen with a cursor....then that's it.
Thanks
BennyC
Edit windows boot options for: VAIO Recovery Environment
Path: \windows\system32\boot\winload.exe
[ /DETECHAL /MININT /REDIRECT RDIMAGEOFFSET=8192 RDIMAGELENGTH=3161088 RDPATH=multi(0)disk(0)rdisk(0)partition(1)\sources\boot.wim
