CSS Checkbox formatting
28 Sep 2008
Britain
Hi guys,
My CSS does some general form formatting, but when I use a checkbox, it applies the border around it (even if I specift border: 0px;). I just want the checkbox on it's own.
What do I need to add?
Code:
/* General form settings */
form
margin:0;
form p
clear:left;
margin:2px 0;
form span.warning
margin-left:0.25em;
color: #ff0000;
fieldset
margin:10px;
border:1px solid #d9d9d9;
padding-bottom:10px;
legend
margin:0 0 0.5em 0;
padding:0.25em 0.5em;
background-color: #404040;
color:#fff;
font-size:1em;
font-weight:700;
label
float:left;
width:220px;
margin:2px 0;
font-weight:700;
color: #404040;
vertical-align:middle;
input, textarea
float:left;
margin:2px 0;
font-family:Arial,Geneva,Helvetica,sans-serif;
font-size:1em;
color:#333;
background-color:#fff;
#checkbox
width:100%
border: 0px;
input
width:20em;
select
float:left;
margin:2px 0;
input.button
float:none;
width:10em;
padding:0px 7px 0px 7px;
background-color:#d9d9d9;
color:#000;
line-height:normal !important;
text-align:center;
font-weight:700;
Could you paste the code you're using in your form for the checkbox?
#checkbox is obviously an ID, are you applying it correctly? e.g.
Code:
<input type="checkbox" id="checkbox">
Should be "border-width: 0;" shouldn't it?
Or "border: none;" [because you need to specify at least a style with the shorthand declaration].
You've crossed the streams, bucko :D
Border: 0px is fine - it uses the shorthand property for border.
The problem - and you'll want to kick yourself - no semi-colon after width: 100% in the #checkbox rule :D
Are you testing something - as having a checkbox which is 100% width is a little odd?
FffffffffffffffffffuuuuuuuUUUUUUUUUUUUUUUUUUUUUUUU
Thanks
Ok, now the formatting is fubar'd. How do I get the checkboxes to align to the left in line with the other boxes?
At the mo I have this:
I've tried, align: left; and vertical-align and float, etc
No, i've ditched that. I tried the negative margin but it made some of the text to the left disappear
Just an FYI, I've removed the border attribute so you can see what the positioning is doing. It seems to be picking up the text area. Basically, I want that box all the way over to the left of the border without the border moving (which is what would happen if I put in a negative px width)
It's because you've declared all input fields to have a width of 20em, which is streching the white space either side of the checkbox, I would suggest assigning the checkbox a width.
