- 31 Aug 2009
- Surrey, UK
Could I, say, Crossfire a Powercolor 5770 and a Sapphire 5770 as long as I flashed them with matching BIOSes? Or do the cards have to be physically identical?
I can promise you that any 38XX series card will crossfire with any other 38XX series card.
I had crossfire 3870 (gigabyte ultra durable ddr3 non reference) with a porwercolour 3850 (non reference) which was later replaced with another reference sapphire 3870. All of the cards were running on a dfi 975xg board which I am still running to this day but with a 5850.
No, promise all you want I know, im not guessing this is fact, I have this issue.
Im not saying it wont work Im saying be careful.
It sounds like you never got crossfire working, have you considered that it could have been your motherboard rather than your cards? Non-reference boards aside, the same bioses should have meant it definitely worked. A reference board doesn't mean much really, they work the same way, just that they've redesigned the layout a bit. Functionality will remain the same, of course. Same GPU, specs and same BIOS means it will work providing there's no fault of the cards or the motherboard and or the motherboard supports crossfire.
Just think about it, a 3850/4850/5850 will crossfire with a 3870/4870/5870 (within the same series of course before some one thinks I mean you can crossfire a 5870 with a 4870), and they're different cards with different bioses and different board layouts.
The cards don't have to be physically identical.
I don't think they even need matching BIOS's.
