Anyone know if the U3011 is going to be a crappy 16:9 screen or a decent 16:10 ?
They're brilliant. Are you looking for anything to be good in particular? Or just that it doesn't have any known major flaws?
No just wondering as I bought it earlier today,
Not sure I will even notice the input lag but for 1.5 k I would not expect light bleed,
*bangs head on desk*
Why do people ask for buying advice after they've bought the product?
Top top tip: If you have no problems with it, don't go on the Internet searching for them. You'll only succeed in making yourself unhappy with your purchase.
They can be found for barely more than £1000...
If I were you, I would send the screen back under DSR, and use the money to buy a Dell U3011 instead. The U3011 is available on pre-order for £1230. Why spend more on an out of date screen?
Send it back while you can and buy a U3011 from Overclockers.
Ive not received it yet might get it canceled
Yes Delpy, do that ASAP! (or cancel over phone?). It will be a bit of a pain if after a couple of months you decide you wanted the U3011.Refuse it on the door and then you don't even have to pay the postage back
You must have a lot of space (and money) !!!For what its worth, I own 3 of them which I use for eyefinity. Only recently in the last week bought the 3rd.
To be honest I would not go back to another monitor. I don't notice the lag and they do bleed a little. But not a massive amount. Its mostly on each edge top & bottom.
But again not noticeable unless the screen is completely black. Only reason I see bleed is when I change the input from one connection to another. As one of them is connected to 2 PCs.
Im hoping my new U3011 will be arriving tomorrow (the magnitude of inputs was what swayed me - even majority of 27" screens dont have many)
Only heard great things about this screen - always been impressed with my 2005? and 2407 previously
