If I were to use:
http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK&groupid=701&catid=48&subcat=153
AND
http://cgi.ebay.co.uk/30cm-PWM-Y-Splitter-Cable---Black-Sleeved---BNIB-!!_W0QQitemZ190441777631QQcmdZViewItem?rvr_id=154076859041&rvr_id=154076859041&cguid=8e490a4012b0a0aa12007d30ffc9b602
with 4 Enermax cluster pwm (4 pin) fans.... connected to my motherboards CPU pwm fan header...
Would it work? i.e. all fans run at the same pwm controlled speed? Any issues with having 4 fans off one header?
Also, can someone confirm why the fans only seem to adjust between 1100rpm and 1300rpm when running off pwm? Is this purely because the cpu runs between 50 and 65c at any time and so the fans don't have a change to go slower?
AND
