Today's roast and another cooking thread - roast rib of Aberdeenshire beef
Caporegime
13 May 2003
Warwickshire
Hello all, today I made roast rib of beef for a very satisfying Sunday dinner.
Here's how it was done!
Meat, on the bone of course. Not the world's finest beef, but it did the job:
Other bits:
Less obvious bits in the above pic include chicken stock for the gravy in the blue tub, concentrated beef stock in the little plastic container, clarified butter for searing the outside of the joint, and a bouquet garni of 1-2-3 bay rosemary parsley. I didn't tie the bouquet or use muslin, as the gravy was being strained anyway. It's also easier to distribute the flavours when the herbs are loose, if the bouquet isn't going in liquid to start with.
Let the beef cool to room temperature for a couple of hours. Season well with sea salt and freshly cracked black pepper (ideally sea salt flakes).
Creat a vegetable trivet from the onions, carrots, garlic, shallots, and herbs:
Add the butter to a heavy pan over a high heat, and sear the beef on all sides to create a nice flavoursome crust. Don't use normal butter as the milk solids will burn. If you don't have or don't want to make clarified butter, use a high smoke point oil, such as vegetable or ground nut. To a point, the higher the heat the better. You need an ultra hot pan to get the necessary crust.
Place the beef on the vegetable trivet and add the herbs. As the beef cooks, its juices will mix with the vegetables and create a nice gravy base at the bottom of the pan. Put the tin in a pre-heated 210 deg C oven. After 10-15 minutes, turn it down to 160 for the remaining cooking time.
Now for the roasties! Boil them for five minutes, then drain and toss them hard in the pan with the lid on to fluff the outsides. Then score the potatoes with a fork. This will help them absorb more fat and get the outsides crispy.
Leave to dry on the side. They need to be dry before we start to cook them or they'll spit like a mofo. Use towel if necessary, or just boil them the day before and put them in the fridge overnight (covered).
Almost registering rare, not long to go:
Back to the potatoes...two teaspoons of goose fat, one of clarified butter in the bottom of a hot roasting hit. Put it over a med-high heat:
Season the potatoes and get them in the hot tin. Sear the outsides and spoon the hot fat over them. Then into the oven at 200 degrees C.
Beef out of the oven. Get it resting in a warm place for at least half an hour.
Put 2 tablespoons of flour into the pan and stir the whole lot around to absorb the juices and cook off the flour:
Add a little bit of water if it's too dry, just to help the uptake of flavours.
Add 1/2 - 3/4 bottle of red wine. I used a £3.50 job from Tesco, many people are of the school of thought that just because you are cooking with it, this doesn't mean that the wine should be cheap. Make your choice, but my feeling is that the main flavour from the gravy comes from other sources.
Now add the chicken and beef stock and cook for another few minutes, before pushing all the goodness through a sieve to catch stuff you don't want to eat.
Now that the gravy's in a saucepan, check for seasoning and texture. I keep a blond-brown ('peanut butter') roux in the fridge / freezer at all times for flavouring and thickening sauces and gravies. A roux is basically a fat of some kind + flour. I use clarified butter with normal flour. This beats corn flour etc. as a thickener in every imaginable way! You can fill an ice tray with it and it will keep for months. Making a roux is another thread, but this is what mine looks like:
Carved; it was pinker than it looks your honour!
Served:
Let us now kneel before the mighty cow :D.
Looks nice Robbie, few things:
Did you make the clarified butter yourself? I've tried a few times, and can never seem to get rid of enough milk - it just seems to take for ever. I've heard you can use a coffee filter to make your life easier. Any tips? When I can find it, I use ghee instead. I love bearnaise sauce, but have given up trying to make it because of the issues I have with clarified butter and can't find it in any of my local supermarkets and the jarred version just isn't the same I'm sure you'll appreciate.
Your roux is awfully brown, mad.
You ever done a Beef Wellington? I'm going to do one next month using foie gras and truffles. Any tips? Probably going to serve it with black & red caviar. (Yeah, that's right. :D)
1. Melt a block of Lurpak unsalted butter in a saucepan, slowly.
2. Skim off any solids that float to the top.
3. Wait for the butter to completely melt.
4. Allow the two layers to settle.
5. Pour off the top layer into a clean bowl/jug/container.
6. Discard the milk residue.
You can strain the whole lot through a coffee filter or some cheesecloth, but you shouldn't need to if you've got a steady hand and are using a milk pan or something similar. You can even cheat and use one of these if you're really struggling.
That's because it's a blond roux, not a white roux.
It'll have a nuttier flavour but thicken less effectively than a white.
Caviar?! What the hell for?
And I wouldn't bother with putting both fois gras and truffles in your Wellington. You'll lose all of the delicate flavour of the liver.
Unless you're making a truffle jus to serve with it, in which case; crack on.
Yeah, it's the skimming that I just can't do. I don't have very steady hands, and all my pots are quite high. Couple this with using the wrong spoon and it's just too fiddly. I guess I'll just have to practice more.
Ah, I've never seen them before - never had to use them. Been happy with my white roux. Will give it a whirl though, always happy to try new things in the kitchen!
The caviar is being used for a few reasons. Firstly, I have it and it needs using up. Secondly, the people who I'll be cooking for have never tried caviar before so I'm happy to indulge them for free. Thirdly, it's something a bit different. I was going to either serve it on thinly sliced toast or thin pancakes, Ukraine style. Either as a side to my Wellington if I go down the poncy route, or as a trio of starters (can't serve up only caviar as a starter to people who have never tried it!)
I was considering using truffles in place of the duxelles, somehow - hadn't really thought it out fully yet. However, I'm now going with the truffle jus as that's a far better idea.
It's a bit of a work in progress at the moment, will be cooking it in 4 weeks or so. I'll try and remember to do a thread on here!
Thanks for the help!
Ah, in that case there's always the method where you heat the butter in a glass bowl over a pan of simmering water, much like when melting chocolate.
That ought to give you more room to manoeuvre when skimming.
Do give it a go. As I said it gives a slightly 'nuttier' flavour, but that's a good thing with certain sauces and stocks.
Caviar is a weird thing for most people who have never tried it before - the thought of it tends to put them off eating it, when they'd probably love the stuff if they didn't have a mindset against it.
Why not go for a trio of starters with varying amounts of caviar with each? That way the guests can be adventurous if they like what they're eating or play safe if they don't.
Whack a glug of Madeira in there for good measure. That'll offset the richness of the meat and the fois gras a treat.
Will you be able to take some photographs while you're at it? Would love to see what you've been getting up to!
PS. Don't forget the pancake in the Wellington.
Do you just discard the trivet vegetables after sieving the juices? The roasted carrots looked good.
Oh aye, never even thought about that. I'll keep trying, sure I'll master it.
That's a good idea:
A salad garnished with nut shavings and caviar.
A spinach (I adore spinach) and caviar filo pastry parcel
Pancakes and caviar.
I'll make sure to defrost some of my French onion soup too, just incase!
Yeah, photos shouldn't be a problem and will put up a thread on here showing my idea of 'at home fine-dining'.
Also how do you guys find the time to take pictures at each stage of the cooking process? I'm determined to give it a go sometime to post on here & a blog but often I'm too busy prepping, stirring, adding things and worrying about timings to remember to do it.
you selotape the camera to your face as you do it
I watched Jamie Oliver's 30 Minute Dinners today and he did a roast dinner in about 26 mins...it looked better than this. And he cheated too, he literally fried the beer and potatoes, so strictly speaking it wasn't a roast as the only thing went into the oven was the yorkshire puddings.
Still, that doesn't look that great, the veg looked over cooked, the beef looked over cooked too.
How did it taste?
