Native resolution for 24inch monitors?
If I was buying I would get a 1920 x 1200 screen
I would not touch a 1920 x 1080 with a barge pole
I have used both and would always prefer a 1920 x 1200
Go here
http://www.displaywars.com/
stick in 24 inch and set one to 16:9 another to 16:10
this will show you the difference between them
On a price vs performance scale though.... is the extra resolution really worth an extra £200 with an increase in reponse time into the bargain?
On a price vs performance scale though.... is the extra resolution really worth an extra £200?
Kinda Depends IF you are a gamer /video player and dont use your PC for
anything serious then 16:9 would suit you
IF you do any desktop / graphics work as well as gaming then 16:10 for the win!
For me personally it will be a cold day in hell when I get a 16:9 lcd for computer use
If you watch films the 16:10 is less wide than the 16:9 as the common diagonal 24" is the same. You will get narrow black bars at top and bottom with a 16:10, unless the picture is stretched
If you want screen real estate, the 16:10 (1200deep) is the one to go for. They are rarer and hence the price.
I own a Samsung 1920 x 1200 24" so am biased, it is easily wide enough for two instances of IE running side by side and deep enough to avoid lots of scrolling.
andy
Well I went for a 16:10 1680x1050 to a 16:9 1920x1080 and it really isn't a problem at all. That could be that I was still actually gaining 30 verticle pixels though. Still, I don't think the 16:10/16:9 thing is really as a big a deal as people make it.
So you didn't go from 1200 down to 1080, which is where you really miss the height. I've been using my Firefox window in a 16:9 shape for the last hour (23") and am thinking I'd miss the height too much. It is far too wide.
16:9 all the way, no borders on my media!
For films you want 1920x1080 cause thats letterbox widescreen, 1920x1200 will give u big black borders top and bottom and generally be a bit of a waste of screen space.
Its not really a resolution thing its just how wide/tall it is, 1920x1200 is taller and thus a lil better for officey type things cause you can see more of a page but for gaming i personally like the 1920x1080 for that cinematic widescreen feel.
1920 x 1200 , will give you a small border top and bottom of the screen , NOT a large one when watching 16:9 movies (anyway most DvD/blu-ray movies are 2.35:1 so you will get bars anyway!)
1920 x 1200 is the right size for 2 A pages to be displayed on screen side by side , 16:9 chops off the bottom of them
As I have access to loads of screens of different lcd's with different sizes , I have actually had a chance to compare them side by side in daily use.
The point i was trying to make is that the argument isn't really a quality thing, its a matter of if you prefer your viewing area to be wider or taller.
