People are right about the new 6xxx series tho, its in your interests to maybe wait a month and see what there like cause even if they disappoint they will certainly drive down prices on the competition
Got a crystal ball have you? If so then why arent you winning the lottery? Nothing is certain, and with the pound continuing to dip and the imminent hike in VAT Im personally speculating pricse will rise, but as I dont have a crystal ball like you I cant say for certain
Also if its a choice between an SSD and 2x GPUS take the multi GPU
, thats just my opinion and im sure some will disagree but i value frame rates over a tiny increase in loading times.
Glad you clarified its your opinion on this one, but its not a tiny increase in load times, its a massive decrease
A single 470 should handle anything you throw at it for some time, whilst leaving the multi gpu option open for future it makes no sense to spec a multi GPU set up initally, especially at the expense of a SSD which in my experience (along with what seems to be echoed by most on here) is one of best upgrades Ive had
Also this is another thread where a lot of people seem to recomend spending 1200 on a PC incl 3-400 (or even 550???) on gfx cards then displaying it on a crappy 200 quid monitor, I moved from TN to IPS a couple of years ago and would never go back, they might be bit more expensive but the image quality is vastly superior
I probably should have explained more in my first post re the monitor, for the benefit of the OP, the monitor I included uses an IPS panel which as Ive just said gives a much better image than "standard" TN panels
Edit: And as I and Porcelina said above, if its purely for gaming then i5 over i7
