- 8 Apr 2009
- Tavistock,Devon,England
erm i am running an athlon x2 @ 3.5ghz and a gtx260 at 60fps with full gfx setting like full AA ect at 1080*??? somthing must be wrong with your rig?
I don't think there's anything wrong with your 5870. The problem is with WOW as a game which it simply doesn't use the extra cores effectively (can't blame them since it is very old game). Your Phenom II X4 955BE at 3.8GHz is no weakling, the problem is the game only using mainly one core for the most intensive tasks, whereas the extra cores are only there to deal with the minor tasks. The reason why i5/i7 would perform much better is than Phenom II overclocked from 3.2GHz to 3.8GHz, that makes it a 19% overclock; let's assume the Phenom II X4 955BE at 3.20GHz is as fast as a i5 750 at 2.66GHz...the i5 750 overclock by 19% is around 3.17GHz, so a Phenom II X4 955BE at 3.8MHz is roughly as fast as a i5 750 at 3.20GHz at best at gaming. A decent i5 750/760 chip can overclock to as far as 4.20GHz on a decent board.Does this mean that I need a new machine in less than a year of buying the new one? LOL
Normally get at least a years worth of full res everything on functionality from my new machines each time I invest....
I must say that I normally go Intel/Nvidia so this is the first main machine that is AMD/ATI... did I make a mistake??
If battlefield bad company 2 is perfectly playable at 6076x1200 on my single 5870 I fail to see how World of warcraft cannot be, unless they have broken the game engine in some horrible way.
If you are curious enough, try dropping your CPU down to 1 or 2 cores and run BFBC2, and see how much performance hit you get getting with the CPU bottleneckingIf battlefield bad company 2 is perfectly playable at 6076x1200 on my single 5870 I fail to see how World of warcraft cannot be, unless they have broken the game engine in some horrible way.
It is a shame though when a game that looks as amazing as Crysis on full runs flawlessly and yet Wow which is cartoon-ish runs like a dog. I understand that it doesnt use all cores yada yada but the amount of money pumped into it you would think that it would be improved quite considerably from that perspective (I think first quarter this year the game has brought in $205 Million pure profit).....
The not going to happen. Update and patches ain't gonna increase the support for the using extra cores better, and in the game's root design it is simply not with Quad-core in mind (bare in mind that when WOW first release, we were still at the stage of transitiion from single-core over to dual-core). To use Quad properly, they would most like near to alter/rebuild the CPU usage for the game from ground-up. I really think the best soloution is they should just release WOW 2 or something with updated graphic engine and CPU support, while accounts can be transfered over from the WOW. But I doubt they are bothered to go through that hassle of spending the effort of doing something so huge, only improving the gaming experience for the end-users. Existing WOW players will continue to play on the WOW on the existing outdated engine, and whereas I doubt there will be too many new players to join the game this late in stage.With the majority of WoW players suffering from significant performance drops in the major cities since classic, but especially since outlands and TBC, you you think that they could have updated the engine to put more load on the GPU and less on the CPU. There is probably a myriad of issues, from the outdated server code to a graphics engine that was designed for graphics cards with no unified shaders.
If you are refering to CPU usage on Windows, it doesn't really have accurate indication on how the threads are run. I'm playing Japanese mmo which is single-threaded, but I get activities reading across the 4 cores on the CPU usage as well. The proper way to compare is to compare the frame rate on 1 core vs 2 cores vs 3 cores vs 4 cores at a low res. If 3 cores and 4 cores deliver no higher frame rate than 2 cores, then the game is simply not using the 3rd and 4th core properly, or not optimised for them.CPU useage seems a lot better when running in the DX11 mode, well I say a lot better I mean more even seems to be roguhly identical performance on all 4 cores, but its still prity low though roughly useing about 30/40% when there is a lot going on.
