Where does an SSD slot into
Most SSDs are 2.5'' (same size as laptop hard disks), and most cases only feature mounts for standard 3.5'' desktop hard disks. So you either need to buy a converter kit (includes brackets and screws) or just rest the SSD on something. Mine sits on the bottom of my case.
Depends which SSD you get also, I know mine came with an adapter so I could put it in a normal HDD bay. But they have no moving parts or get hot so really you can put them anywhere in the case.
Sorry to raise this again. But one final question on SSDs. If your machine is always on sandby, like mine, it restarts pretty quickly. is there still a case for having an SSD running the OS?
You can, I have disabled hibernation mainly due to the low SSD size but use standby periodically.
It should still load problems a lot quicker than nearly any mechanical drive at the very least :P
