will that work with my batteries they have a tamiya connection.
The iMax B6 is a very good charger yes, but it wont balance the packs you are using. When you balance Li-po's its because there are the balance leads wired to each cell. With the 7.4V Ni-MH packs you use they don't have the balance leads wired up as its not as vital on Ni-HH cells as it is on Li-Po cells.
That said, as long as you are aware of that, its still a very good charger for what you want.
how far out does it need to go 1-2mm?
No charger will balance charge Nicads or NiMH packs as they only have the two leads so it is not a failing of the charger that you cannot balance charge those types.
when i push it round it feels pretty smooth another pic .does anything look wrong
is the battery i thought was good not right or is the new batteries overvolting?
Neither, as has already been said, it's to do with the mAh, your 'old' battery is just Pathetic at 1800mAh, thats all.
on this question i meant the fact the car seemed to be nearly twice as quick.
i know MAH simply means how much charge it can hold thus giving longer running times but does it affect the speed is what i'm trying to find out i guess?
Changing to higher amps wont affect the speed, only the runtime, but you will find the newer pack can supply the power more efficiently and you'll get a speed boost from there.
