Update driver help
20 Apr 2008
West Midlands
ok guys, basically have just reformatted my PC and Win7 has kindly installed all my drivers for my motherboard for me etc.
now i want to run the chipset driver which i got from Asus but it wont instal over the one windows installed.
i know there is a command you enter on the end of the RUN command but can't remember what it is. can anyone help?
basically i go to RUN and enter:
D:\Home\Downloads\ASUS Drivers\Chipset\Intel_ChipsetInf_V9111014\Intel_ChipsetInf_V9111014\Setup.exe
at the end there should be an UPDATE ALL command or similar which forces the update.
any help would be appreciated
Don't use the one from the motherboard manuf site
Just google..
majorgeeks intel chipset
Download and install that, likely to be newer
At the time of writing, it's on 9.1.2.1008
Works for all intel chipsets, if it can't find a driver that you need, it just skips over them
seems to have done the trick. cheers fella
also found the command to enter after.
it's RUNALL
this will force the updated driver over the existing if Win7/vista is being a pain
i entered as so
C:\Users\Martin\Documents\INF_allOS_9.1.2.1008_PV.exe RUNALL
