position:relative why differences in browsers?
7 Jan 2007
Sussex, UK
Hi,
I cannot understand this... How come my HTML/CSS displays different things in ie, firefox, opera, chrome and safari?
I'm knackered now but will post up my mess tomorrow.
Why can't browsers display the same way? Maybe it's me who has made a total **** up here :(
I have created two divs with boxes in each and I want one to display on the left of the webpage and the second on the right.
As soon as I do this I cannot get the right positioned div to align with the left, consistent on this 5 browsers... it's driving me to drink.
What's the secret? Let me into the special club :(
I cannot understand this... How come my HTML/CSS displays different things in ie, firefox, opera, chrome and safari?.......Why can't browsers display the same way? Maybe it's me who has made a total **** up here :(
This basically comes down to the fact that every browser renders content differently to some extent. Normally its actually better to write your page for firefox as its considered to be the most compliant. Microsoft has problems interpreting what is considered to be valid, modern-day CSS solutions. A lot of sites these day actually have different style sheets for IE,6, IE7 and IE8 which says it all really.
Paste all code(or provide a link) we will be glad to help you out :)
Paste your code here so we can take a look. TBH, I very rarely have to style for an individual browser, although I don't do IE6 anymore which helps!! If things don't look consistent across browsers, I try to look at an alternative that will work across the board. So much easier for ongoing support.
There is no secret. Just years of learning why and how CSS works in different ways. Eventually you learn the key inconsistencies and find ways around them. The best approach is to have all of the browsers open and iteratively test as you develop a site. That way you catch the differences early and can trace the bug.
That said, you shouldn't have any issues with the modern round of browsers. FF 3.5, IE8, Chrome all render nicely.
The issues really begin when you try backwards compatibility to IE7, 6, which still hold enough of a market share to have time invested.
It is a horrendous pain, and IE will always be the biggest problem but you'll learn soon enough what kind of things to avoid or how to go about certain tasks.
Use a 960 Grid or Blueprint. I found it helped a lot with cross-browser compatibility.
Also... welcome to the world of web building, where we all hate IE. Don't forget to validate and constantly check cross browser compatibility. I use NetRender.
p.s. I build for Chrome.
Where's your html/head/body tags? DOCTYPE? When someone says post all of the markup, they mean all of the markup :p
Where's you html/head/body tags? DOCTYPE? When someone says post all of the markup, they mean all of the markup :p
I don't need it because it gets inserted into wordpress where that stuff is already in there.
I'm creating custom pages in wordpress.
Maybe this is why it doesn't render right lol
Build for Chrome or FF, then check it in IE. If it doesn't work, there are conditional statements.
Remember before I said sometimes the best thing to do is wipe the slate clean and redo it from scratch. Seems tedious but it really can help. Build the template, then import it into Wordpress. So .html first :P
I've already built it from scratch once lol.
I think the problem with the page is the fact that I enclosed all the big leftside boxes in a div and all the smallboxes on the right in another div. This seems to cause all the problems.
Without the divs, like on my frontpage, using position: absolute; the objects position properly, except in IE. But I can fix that using a seperate style sheet where I can turn off all the CSS3 effects as they are a real problem in IE :rolleyes:
The downside to using absolute position is that I am going to have to create yet more div id's so I can position each small box individually.
Is this what you guys would do? or can anyone fix the issues with the wrapping divs I used for the boxes?
Semi-fixed it.
I have removed all margins to all the boxes and got them consistently looking the same in opera, firefox and chrome.
Gonna save this version then try and workout a sensible margin system.
Fixed it!!!!
What I had done was set the margins first, then tried to position the boxes, which was a total failure.
Lesson learnt is, position the object first then set margins.
Hell it works perfectly fine in opera, firefox, chrome and IE9!!!
Those browsers are easy Oxy.. you could throw code at them all day long and they can interpret it nicely!
Get yourself the free microsoft VMs to test IE6 and 7 and then let us know how happy you are! :p
I've never used it and unfairly I already don't trust it... ever since I got burnt by emulations of the rendering engines I've used VMs.
Is that program accurate? And not just a viewer? The sites are functional to test? Does it also have something like IE Dev toolbar built in?
OK used that program that Jester suggested, it's very good!
My website is blank on ie7 and the absolute positioning doesn't display on ie6. It is perfectly visible and readable in ie8 but minus all the css3 effects, which doesn't matter.
Do I need to care about ie6 and 7?
How much more work is involved?
