quick spec check
cheers what cooler would you suggest, i was looking at arctic cooling freezer 7 but not sure if it would fit in an antec 902 case cause of the top fan?
the top fan "big boy fan" is a distance away from the cpu cooler, so wont be an issue.
so many decent coolers on the market, its hard to pick just one.
Titan Fenrir EVO, Akasa Venom, Coolermaster 212?
i actually meant the air flow effecting the top far as i wasnt sure what direction the artic cooling fan moved the air
good question, I dont think the airflow within the case is sufficient to really affect the rule that heat rises(unless you have the fan controller set to "tornado" lol), also I dont know if the mounting holes for a socket 1156 heatsink are Square allowing you to rotate the heatsink by 90degrees to point upwards?
even if you cant rotate the cooler, there is a fan on the back suck the air out too.
my opinion is - dont worry about it.
