*****NVIDIA PRICE DROP - GTX 460 & 470 DOWN IN PRICE!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right guys, we've now activated this price drop across the whole range, please remember when you buy from OcUK you also get added value as you get FREE MAFIA 2 or HAWX 2 with qualifying NVIDIA cards, plus loyal forum members also get FREE SHIPPING:-
Here are some highlights:-
OcUK Value GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 @ £187.99 inc VAT
Next-generation gaming has arrived. Nvidia GeForce GTX 470 gives your games an adrenaline shot with screaming fast performance and futuristic, visually stunning graphics. Experience heart pounding,
cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jaw dropping
stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 470: pure adrenaline meets visual bliss.
- Core Clock: 607MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3348MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 448
- Shader Clock: 1215MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
- Supplied with Full Mafia 2 PC Game as of 27/08/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
Only £187.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 470 OC 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 @ £199.99 inc VAT
- Core Clock: 630MHz
- Shader Clock: 1260MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Supplied with HDMI Cable
- Warranty: 2 Years
Only £199.99 inc VAT.
ORDER NOW
Palit GeForce GTX 460 768MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £119.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 675MHz
- Memory: 768MB GDDR5
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 336
- Shader Clock: 1350MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a
- SLI Ready
- HDCP Capable
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
- Supplied with Full TOM CLANCY's HAWX2 PC Game as of 18/10/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
Only £119.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 460 OC 768MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £129.99 inc VAT
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
The special inclined dual fan design effectively minimizes the flow of turbulence between two fans and enhances heat dissipation of hot area right underneath each fan. By unique design, WINDFORCETM 2X even enlarges air channel on the graphics card vents and creates a more effective air flow system in chassis. This special design helps heat dissipate quickly from GPU. In addition, WINDFORCETM 2X is equipped with 2 copper heat-pipes which strengthen the speed of heat dissipation.
Features
- Core Clock: 715Mhz
- Memory Interface: 256-Bit
- Shader Clock: 1430MHz
- Display Connectors: 2x Dual-Link DVI-I & 1xHDMI & 1 X Analogue
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Only £129.99 inc VAT.
ORDER NOW
OcUK Value GeForce GTX 460 1024MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £144.98 inc VAT
- Memory: 1024MB GDDR5
- Display Connectors: 1x VGA, 2x Dual-Link DVI-I & 1x HDMI 1.3a
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Only £144.98 inc VAT.
ORDER NOW
MSI GeForce GTX 460 Cyclone 1024MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £159.99 inc VAT
Cyclone Thermal Design
- 9cm PWM Fan for 40% more airflow.
- Nickel-plated copper base for better dissipation.
- Rounded design to prevent keeping dust.
- 15.7% quieter than reference design.
Military Class Components
- Hi-C Cap provides more precise GPU voltage.
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- All Solid CAP for longer lifespan.
MSI Afterburner overclocking utility
- Support Over Voltage function of GPU
- Support advanced fan speed control.
- Support burn-in stability test.
PhysX & 3DVision Surround technology
- Support PhysX technology effects for realist physics effect.
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience.
Specifications
- Core Speed: 725MHz
- Memory Speed: 1GB GDDR5 3600MHz
- Memory Type: GDDR5
- Memory Size(MB): 1024
- Memory Interface: 256 bits
- 2x Dual Link DVI
- 1x mini HDMI
- Support Over Voltage function of GPU, PLL and Memory
- Online Live Update - Supplied with Full TOM CLANCY's HAWX2 PC Game as of 18/10/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
Only £159.99 inc VAT.
ORDER NOW
NVIDIA GTX 470 Range - New Low Prices - MAFIA 2 FREE - Click Here!
NVIDIA GTX 460 Range - New Low Price - HAWX 2 FREE - Click Here!
I don't think anyone can argue now what incredible value the 460 and 470 range is now from NVIDIA. :)
Very nice price's... Unlucky for me though as i was going to sell my Gigabyte GTX460 1GB, So i could get a reference card and Watercool :o
tempting, I think this is the time to upgrade my aging GTS :>
is going to GTX460 from GTS250 be a big difference?
(yes im an nvidia fanboi)
