nzxt phantom case fan connections
24 Apr 2007
Derbyshire
i have been building my new pc build and wanted to confirm the case fan connections on this case do they go straight to psu power supply or attach to motherboard and where too. i have the sabertooth x58 motherboard.
Also does anybody know how to fit these hard drives using the screwless cage design?
thx
thx
All of the case fans can be controlled by the fan controller on the top of the case. The 3-pin cables are included, just plug your fans straight in to them and select the speed you want on the controller :)
regarding fitting the hard drives.
i have a nzxt hades.
you need to screw the U shaped metal frames to each side of hard drive.
then remove the screwless catch at side (out side) of hard drive enclosure.
slide in hard drive and line up hole with hole in drive enclosure.
put screwless catch back on and turn the little catch 90 degrees.
umm what now?? on the phantom hdd trays you have to bend the trays to get the pins into the holes on the hdd untill they stap into place, this is explained on the instruction manual :D
