OCZ Power Supply Deals! Amazing Value - whilst stocks last
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Guys
To co-inside with the new ATI 6800 Series GPU launch, we have struck a crazy deal on 2 OCZ PSU's which are great option to power the new GPU's.
The prices shout louder than anything else I can say :)
*** PROMO *** OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply @ £58.99 inc VAT
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 140mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- up to 86% Efficiency
- Overvoltage/OverPower/Short-Circuit protection
- (.99)Active PFC
- MTBF: 100,000 hours @ 25C
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
Was £72.99 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
*** PROMO *** OCZ StealthXStream 2 500W Power Supply @ £30.98 inc VAT
The new StealthXstream II strikes the right balance between mainstream power needs and high-performance build quality to deliver unprecedented value. Designed for both gamers and mainstream power users in mind, key features of the sleek StealthXstream II include a thermally controlled 120mm double-ball bearing fan maximum airflow at near-silent audible noise levels, exceptionally well regulated electrical noise and ripple for stable operation, an ideal array of connector types for each wattage, and excellent efficiency, converting up to a full 82% of AC to DC power at typical loads. The StealthXstream II Series from OCZ is fully compliant with the latest ATX12V and EPS12V specifications.
- Series: StealthXstream II
- Type: ATX12V V2.2 / EPS12V
- Wattage: 500W
- Fan Size: 120mm double ball-bearing
- PFC: Active
- Main Connector: 20+4-Pin, +12V Rails: 2, PCI-E Connector: 1 x 6-Pin, SATA Power 4
- Efficiency: Typical load 82% Efficiency
- Energy Certifications: 80 PLUS Certified
- Input Voltage: 100 – 240V
- Input Frequency Range: 50/60 Hz
- Output: +3.3V@24A,+5V@24A,+12V1@18A, +12V2@18A, [email protected],+5VSB @ 2.5A
- MTBF: >100,000 Hours
- Dimensions: 15cm x 8.5cm x 14cm (W x H x L)
- Connectors: 1 x Main connector (20+4Pin), 1 x 4 Pin, 1 x 6-Pin PCI-E, 6 x Peripheral, 4 x SATA, 1 x Floppy,
Was £49.99 Inc. VAT
Only £30.98 inc VAT.
ORDER NOW
Normal promotions are a week but this one may be a little longer. A Mod should clarify shortly.
Some people don't like these PSU's but my 500W ModXStream has been more reliable, so far, than my Corsair which costs 4 - 5 times more! :)
Thinking of getting one of these for my dad's build. I popped into a certain large competitor today & they had these for sale (no price on the shelf though - typical!) :rolleyes: I picked the box up & it felt quite heavy for a PSU, which to me is usually a good sign of a good quality PSU, better than the makes you can buy from certain high street retailers. (especially for the price OCUK are selling them for)
What I want to know is are they quiet?
Only 3 Sata connectors :confused: OK you can get adaptors but that's beside the point when PSU's in its original price range have 4.
BTW all he Does in the video is unbox it & gives a description & his experience of OCZ's RMA service, he's not fitted it in a rig, powered it up & showed us how noisy or quiet it is. 3 Year warranty on a PSU in this price range is good though.
yet OCZ website specifications confirm its three
Yeah I checked it on there before I posted my last comment to make sure.
I can't make my mind up whether to get one of these or the Corsair CX430. I just wish I'd bought a CX400 when they were on offer a month or so ago, but I didn't have a build planned back then. :(
It's in a Antec 1200 now and even when the case fans are on low you still can't hear the PSU fan :)
2 x modular cables with 3 SATA power connectors that's enough for 1 x optical and 5 HDD's ( you building a server?...LOL)
In my Antec I just use a molex>sata adapter to reach up to the top of the Antec... Siiimplessss
THIS IS FOR THE MODXSTREAM - modular cabled
Your just up the road from me Grimley (Mike) and your welcome to pop in a check it out :)
^^ Also got the 600w Modstream. Not the most fashionable brand of psu but mine has worked flawlessly for the last 6 months or so and is silent too. OCZ PSUs are great value for money imo.
