OK no apologies for being a newbie we've all been there...
So the day has come when I've finally decided to build a new system, last time I built as system was 6-7 years back so things have moved on.
I've plumbed for a i5 760 2.8Ghz (unclocked) Cooling fan I've gone for is Gelid Tranquillo and my case choice is a CoolerMaster 690 II.
So here's where the daft questions start.
1. Gelid comes complete with thermal compound, should I go with that or buy something else? In the past I've used the thermal pads that are less messy.
2. How do you apply it? one big dollop in the middle, several little blobs, stripes? I assume the idea is to cover the whole surface to avoid an 'hotspots'
3. Air flow? How should I be setting up the fans? in particular which way should the CPU fan be pointing.
I know it's all sort of trivial stuff, but if you don't ask you don't learn?
