So suggestion would be to sell my q6600 for £70ish on the MM, sell the board for £20ish and put that towards an i5/new dual channel ddr3 board?
So no one went DDR3 on a Q6600 really?
Really don`t get any nforce, stay away from it especially lga 775.
They have many problems, I am using a 6870 and I cannot even restart because it will not detect the card.
Hey all,
Trying to find myself a motherboard that supports the 775 socket (for my q6600 G0), my dd3 ram, and 460's in SLI. Can't find one.
It's for a full tower, so ATX.
Any ideas?
S
It will support 4XX series cards - they are all PCI-E 16XI think you can use 790i which support ddr3 but i am not sure about 460 sli, but i do know it does support your memory and cpu
Q6600 + nForce chipset = fail...
Aside from some 790i boards the only other nForce boards that are semi acceptable are the gigabyte N650i DS4 and the EVGA 750i F.T.W. edition (not the regular non F.T.W. - the F.T.W. version is closer to a cut down 790 than a 780/750 board) - neither of which will do stunningly well with a Q6600.
