Hi All,
I'm really stuck. There seem to be sooo many boilers, and so many differing opinions.
I need a new combi boiler, I'll be buying and the fitter will be fitting. I'll be getting a POWERFlush, cleanser & inhibitor, Magna Clean ...and maybe a lime fighter (or maybe not? - thoughts?).
I have 6 radiators and one bathroom. I currently have an old combi - NON-condensing.
I was wondering what boiler I should buy? Any advice?
For me the longer the part & labour warranty the better, and it seems some cheaper brands (Ideal) are offering 5 years.
I was also wondering whether thermostatic vale on the rads would be worth fitting, as bar maybe one room, all others tend to require the same level of heating - so if i installed thermo valves I'd end up keeping them on MAX everywhere except one room.
If anyone has any recommendations I'd really appreciate it.
Thanks,
R
Thanks,
R
