Hello everyone..
I have a question, regarding the system im planning on buying, which as stated above is the "Ultima Dreadnought". Link;
http://www.overclockers.co.uk/showproduct.php?prodid=FS-132-OE
I plan to add a 80gb SSD to this system, but then was thinking about upgrading the RAM also.
Now i plan to save about £60 on the original monitor i was going to buy, so i thought about upgrading the Ram with the money i saved.. but ill put the upgrade up to £100 give or take a few quid.
So i have a simple question, what kind of RAM upgrade would be worth it for £100?
Also, a couple more questions if anyone cares to answer;
If i increase the RAM from 6gb to 12gb, would the speed reduce?
And
Would it be best to upgrade from 6gb 1600mhz to 12gb 1600mhz or upgrade to 6gb 2000mhz? Seems 12gb of 2000mhz is still quite expensive!
Thanks very much for reading
Kyle.
P.S, Forgot to mention what i run on my computer if it makes it any better, i run World of warcraft, iTunes, Multiple web browsers with multiple tabs and i plan to have a 2nd monitor to use for MSN and other little bits and bobs lol.
*Edit*
Forgot to ask, when i ring overclockers to order this system, will they be able to fit the ram and optimize it? So i dont have to set anything up?
And
Kyle.
*Edit*
