Man of Honour
- 5 Jun 2003
- Falling...
Argh, can't believe I wrote Chernobly, and now you've quoted it too!
but what does this have to do with us reinvestiing in nuclear tech.
FYI - I assume you mean "inextricably" rather than "inexplicably".
Is one of the myths that WE'RE ALL GOING TO DIE ZOMG!
Don't see any mention on that list of what happens to the waste fuel after it's been used up.
Does anyone know what reactors we'd use in the new stations? PWR like the rest of the newer power stations?
I think the main problem with nuclear power is just general ignorance of the majority of the public, for the past 60 odd years they have been told anything nuclear = dangerous, not helped by the chernobyl incident or other such disasters, so obviously whenever the subject of nuclear power is brought up everyone is a bit wary of it and the greens and other such completely ignorant people play on this.
yes it can be dangerous, but if done correctly is completely safe and relatively so mch cleaner.
the way i see it, nuclear power is the only reasonable solution until a more practical cleaner source of power is found.
the british population needs to get over its phobia of nuclear.
and before anyone starts with the whole nimby stuff, i wouldnt give 2 hoots if i lived next to a powerplant.
Noticed an error in the article (at least I think it's an error). They say uranium is only fuel to produce more fuel when burnt? How so? burn would, get charcoal (if done right)... now technically this is producing more fuel even though the process isn't used for 'fuel', but could quite easily be, after all a Nuclear reaction is just a controlled process.
I really dont understand how people cant accept that nuclear is a great source of energy as part of a whole diverse solution.
Thats an INCREDIBLY naive view, if done correctly, its safe, thats rubbish.
Sorry but mistakes and accidents happen, thats life, this is proven, and the biggest problem with that is you CAN NOT PLAN for every eventuality, no matter how thorough you think it is there is ALWAYS something that can go wrong.
When a coal power station has a problem, gets out of control, burns out of control, the local population won't glow, and have cancers, and have cancer ridden children for the next 100 years.
Nuclear is simply NOT that safe, if a problem occurs with it, the potential for massive massive catastrophic failure that injures/kills many many people is ALWAYS going to be there.
This is where the argument fails, the pro nuclear side trys to put across this 100% safe idea, the public falls for it, one accident happens proving the idea its 100% safe is utterly utterly ridiculous and no one ever trusts the "its safe" PR people ever again.
If they simply sold the idea as, its incredibly safe, will save billions, is sustainable for far longer than coal/oil/any other types of power station and its really the only choice, and come up with ways to minimise the risks they'd get much much better reaction than this truly idiotic idea its completely safe with no risk.
The risk is MASSIVE, half of life is a massive risk, the public need to be sold on the risk vs reward, not sold on the stupid and idiotic idea its completely safe for ever.
The biggest problem really is due to loss of power over length its not hugely economically viable to move everyone off one of the crappy islands around the UK, load it up with nuclear power stations and have it offshore with lower risks if a meltdown occured.
AS for the waste, its not as little a problem as the article makes out, its not the volume its the difficulty.
Its moving it around to be reprocessed, its the expense of creating the containers to stick it in.
Yes it might only create waste the size of a royal albert hall. But that has to be built, underground, in a location that if any leaks did happen, wouldn't seep into ground water, or near any local population, it has to be built to be earthquake proof so the walls hopefully will never crack, to not explode under pressure/heat, to contain the radiation and, etc, etc, etc. Its VERY expensive disposing of the waste property, there is a risk to a truck transporting the waste having an accident, or being a target for attack, of a crash causing a ridiculously dangerous spill etc.
Even then thats not that big an issue, its just not a small issue, in a long list of fairly big problems, amongst the fundamental one that should a nuclear reactor go critical and be a problem, it can effect a simply massive area or problems. Chernobyl caused problems with radioactive rain as far away as Wales.
Also you have the political situation with nuclear power, ok the UK and USA accept it completely, deem it completely safe, etc, etc, we both get 50 power stations each, whoopdedoo.
Now Iran decides, well you have them, so what can you possibly have against us building them. As oil prices continue to rise, Pakistan wants them, Afghanistan wants them, Khazakstan, half of africa.
The political force behind us refusing to help these countries build/learn nuclear power tech is pretty strong when we pretty much refuse to build more stations due to safety issues.
Do we want the ENTIRE GLOBE to end up with nuclear power stations in 20-30 years, of which maybe the UK/USA ones will be of a sufficient safety record, will every one built everywhere else in the world offer the same safety?
Will every worker who helps build the reactors in the UK/USA/Nigeria all of them not make a single mistake, not a single steel girder with a single fault causes a problem eventually?
A coal power station breaks down, it effects almost no one, a nuclear power station going can have worldwide effects, we get loads of our fruit and veg from Africa, what if one year it call becomes irradiated, and for 50 years the place is irridated.
The BIGGEST problem with nuclear power is NOT how safe it would be here, but the long term implications of the "1st world" accepting it as safe and the prefential choice, and the knock on effects of other countries with significantly lower safety standards pushing into the same area's.
Everything can be worked out using maths, those people dont understand maths..
Pretty simple
