I have the - Vaillant ecoTEC Plus 837 Combi Boiler
The reason why, was because the flow rate of the boiler was real good.
Unfortunately running two things at once is not good.
What type of shower?
If you have a shower, it's using a lot of water. If it's a power shower fed off the mains hot and cold or an electric shower fed off the cold water supply, any other flow of water will affect the shower.
Tap, wc cistern filling will affect this flow. The shower should then regulate the temperature accordingly for the drop in flow.
You can run more than one thing at a time but the flow rate decreases for each item running. Ideally running a shower and something else is not a good idea
