- 13 Sep 2010
I'm in a similar boat to you Ryan, although with a different case (antec 300). Have you considered the idea of multiple rads?
e.g. you could go for a double in the top as discussed above, and a single on any other available 120mm slot (rear, or in your case (pun unintentional), there is one at the bottom).
[anyone with experience of similar setups please feel free to point out any floors in this plan, its just an idea I had, never WC'd properly myself]
also if it happens that the space between motherboard top edge and case is insufficent for push/pull, have you considered mounting 2 of the fans externally on top of the case? I was thinking of doing this on my antec, possibly with a custom made beveled surround/top panel to make it look more subtle.
as another alternative, if you don't mind noise....
http://www.overclockers.co.uk/showproduct.php?prodid=FG-022-SY
got 2 for my mate as his i7 920 bundle @ 3.8ghz was getting far too hot, dropped 15 deg. celcius (ish) at load vs 2 noctuas (on the noctua U12 cooler), they aren't too loud for the amount of air they push (110cfm for 37dB if memory serves), but the pitch/frequency of the noise is quite penetrating
edit: memory does serve, and fan specs are in store page!
Bright pink, think even the other half might approve of that
