Ok thanks a lot.
Seems a nice site, will be sticking around for a while.
errmm how about that guy who keeps creating threads about Razer's "leet"? competition thingy? lol
Who knows, maybe I'm one of them.
Or not..![]()
Haha!
So are you all sorted with your spec?
Correct.
32bit can only use a max of 3.5ish GB of RAM.
XP can only use 3GB (from what I've heard - I've never used it), so Windows 7 is the best bet!
If the main use of the pc is gaming then these builds are pointless and no more than a sidestep. The performance gains are simply not worth it. The socket that i3/i5 is based around is going to be killed off in a couple of months as well which means that the next time you want to upgrade you will need to replace everything again.
Best bang for buck would be a new graphics card provided your psu is powerful enough.
Interesting post.
I have no idea how to look into my PSU on my current build, could I use software to determine the power o0r would I have to manually look?
