Exercise bike v cross trainer - home use
1 Feb 2006
As per title really... can't be bothered with running out to the gym anymore so was thinking of getting either of the above to help do a little exercise at home.
I always liked the bike but some of the other family members will use this machine too so something like a cross trainer is probably a better allrounder.
I have been looking at some x-trainers on the Jungle for around £300. Would these be decent at that price? York is the make that I recognise as being well known. Are they a good bet?
York is well known as it is sold in Argos.
It's a budget range.
Think about how much it will be used, the more use the more you should spend really.
Ah that explains why it's a household name then. It will probably be used for a few hours every week.
Any other brand names I should be looking at?
Most machines should be ok for a few hours a week, it's whe you start getting 3-4 hours a day that you need to consider something more robust.
Got to ask yourself, if you can't be bothered going to the gym. Can you be bothered doing anything in the house?
Yes it is the time taken to get to the gym that puts me off. I never have the motivation to leave the house and go.
And this machine is cheaper than 12 months gym membership so it wouldn't be a major financial loss either.
Cross trainers - Cant comment on the one you are looking at, but if you get the chance i'd nip down to a local fitness place like powerhouse and try a few out. they have a decent range at my local place and i tried them all going from £200 to £1500, the lower end stuff felt very shaky, as soon as you got over £5-600 the machines themselves got a bit more sturdy and it was the functions that changed. There is also a difference for the footplates and how your feet 'sit' on them. I ended up with a Vision Fitness one for around the £700 mark (was up for a couple of hundred quid more), it gets about 1hrs use 5 times a week and is now two years old, hasnt missed a beat yet.
