How bad is your hearing?
27 Sep 2005
London innit
http://www.noiseaddicts.com/2009/03/can-you-hear-this-hearing-test/
I can hear the 12Khz, nothing on the next step up.
Edit: Safety tips
When you listen to this, listen to it at normal volume. If you find you cant hear it, do not turn the volume up as the sound is still very loud. There will be some variation in response because everyones setup is different and the high frequency sound at 22KHz is pushing what normal audio equipment can produce.
The point is to find when you hear the drop off in volume, not how high you can hear with 100DB pumping into your ears. I can hear 14KHz at the same volume as tones below it, 16KHz is very quiet and have to stick speakers onto 11 to hear it.
I could hear 17 khz, nothing after that.
I am 28. 17 khz was quite audible. anything after nothing at all.
listening on headphones.
I can't hear anything past 16khz (I am 29).
I wear earplugs most of the time when at the computer, too.
I suppose my hearing isn't as sensitive as I thought it was.
I can hear those bird scarer thingies people use in their gardens though.
Hear 15 fine, 16 and 17 I can notice they start and stop but nothing inbetween. And now I have a right bad earache. Thanks.
If I crank my volume all the way up with headphones on I still can't hear over 12 :(
Too many years spent in nightclubs hugging speakers.
not trying to brag here but 14 - 16 are very audible for me. I dont think I have great hearing either, esp my left ear.
Everything above 18 I couldnt hear in the conventional sense but hurt my head and I could "feel" the noise (as in it was still registering as another sound but not quite audible)
