THIS WEEK ONLY - Great Halloween Deals (27/10/2010)!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some spooktacular deals for you THIS WEEK ONLY:-
Belkin F7D4401UK Play Max N+N/802.11n Wireless Router ADSL @ £84.99 inc VAT
Belkin’s PlayMax Wireless Router with the latest Dual-Band N technology, gives you the fastest, most reliable speeds for streaming video, playing music and gaming online.
What is Dual Band Technology ?
Dual band Technology gives you even more strength and signal coverage in your home meaning you will get maximum bandwith optimization.
-Performance – Step up to better wireless High-Performance Dual-Band Networking N+N/802.11n
-Speed Dual-Band 802.11n for speeds of up to 300Mbps*, with high-speed Gigabit ports for media-intensive applications
-Coverage MIMO technology provides maximum coverage for demanding home usage
-PRESET SECURITY Security settings are preset to get you up and running safely
-VIDEO MAX HD Dual-Band optimizes multiple media files like streaming HD video and games
-BIT BOOST™ Prioritize traffic on your network for video, gaming, and VoIP
-TORRENT GENIE*** Download large media files like movies, music, and games, even when your computer isn’t on
-MUSIC MOVER™ Play music from your library on your stereo through devices like Xbox 360® and PlayStation® 3
-DAILY DJ™** Get daily personalized playlists based on your music library and tastes
-MUSIC LABELER** Automatically identifies and labels your music
-PRINT GENIE Print wirelessly from any computer
-MEMORY SAFE™ Auto-backup of photos and files
-SELF-HEALING Detects and resolves network problems
-Easy Setup - Set up your network in minutes Easy Start 1. Plug router into modem 2. Plug router into wall 3. Insert startup disk for quick on-screen setup
-Powered by an ENERGY STAR® qualified adapter for a better environment
2-Year Limited Warranty
Was £119.99 Inc. VAT
Only £84.99 inc VAT.
ORDER NOW
Belkin F7D4402UK Play N+N/802.11n Wireless Modem Router ADSL @ £82.24 inc VAT
Was £85.76 Inc. VAT
Only £82.24 inc VAT.
ORDER NOW
Belkin 300Mbps N+ Wireless ADSL2+ Modem/Router with Storage Port (F5D8635UK4A) @ £43.46 inc VAT
Belkin's N+ Wireless Modem Router is based on the draft 802.11n 2.0 technology which provides a wireless network that has the range to easily cover any-size home or office. The N+ Modem Router has the bandwidth and speed for handling media intensive applications that take up large amounts of your bandwidth.
A USB Storage port on the back of the router enables you to connect USB storage devices such as an external hard drive or thumb drive to the network, saving you having to connect directly to individual computers on the network, this can reduce the electricity you use, thus saving you money. Now you can centrally store and share media content and files from the USB hard drive to every computer on the network.
The N+ Wireless Modem Router is the central connection point of your wireless network. You can add up to 16 computers to your Wireless Network with additional desktop and notebook adapters. Position your Belkin Modem Router in between your Broadband ADSL line and your computer to start sharing your broadband Internet access.
- USB Storage Port for easily connecting USB storage devices to your network
- 4 Ethernet Ports for Wired Connections
- ECO Features, Automatic Wireless Disable and Dim LED Features.
- Draft 802.11n 2.0 increases your networks wireless range and speed than 802.11g
- Download Speedometer bar that measures the download speed of your broadband
- Compatible with ADSL, ADSL 2 & ADSL 2+
- Push Button Security (Wi-Fi Protected Security)
- Easy setup Assistant and troubleshooting with Network Status Display to help you diagnose any network issues that may arise
- Free 24/7 technical support (local rates apply)
Was £45.81 Inc. VAT
Only £43.46 inc VAT.
ORDER NOW
Belkin Wireless G Modem Router Network Kit (F5Z0102UK) @ £22.31 inc VAT
Connecting the G Wireless Modem Router to your ADSL line lets you share your broadband Internet account with all your home computers. The G Wireless USB Network Adapter connects our desktop or notebook computer to your wireless network.
Key Features
Wireless G Modem Router (F5D7634uk4A)
- IEEE 802.11g/b Compliant
Wireless G USB Adapter (F5D7050ed)
- Fits any standard 1.0, 1.1 and 2.0 USB slot
- Compatible with 802.11b and 802.11g devices
- Features wireless 64- and 128-bit WEP Encryption
Was £23.49 Inc. VAT
Only £22.31 inc VAT.
ORDER NOW
Kaspersky Internet Security 2011 (3 User) - Retail (KL1837UXCFS) @ £22.99 inc VAT
Kaspersky Internet Security 2011 has everything that you need to stay safe and secure while you're surfing the web. It provides constant protection for you and your family - whether you work, bank, shop or play online.
- Real-time proactive protection against all Internet threats
- New Safe Surf feature for unparalleled online security
- Protection for your digital identity at all times
- Feature-rich and effective Parental Control
- Application Control prevents dangerous software from harming your system
- System Watcher technology
- Unique Safe Run mode for apps & websites
- Special tools to treat even the most complex infections
- Easy-Access Desktop gadget
Was £38.76 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Samsung SpinPoint F4 320GB SATA-II 16MB Cache - OEM (HD322GJ) @ £30.54 inc VAT
The Spinpoint F4 features 7200rpm speed rotation, advanced areal density technology and a SATA 3.0 Gbps interface. Equipped with Samsung's exclusive dynamic balancing technology, the drive's overall stability and reliability is optimized as a high performing solution. Samsung's proprietary SilentSeek and NoiseGuard technologies are incorporated in the drive to offer ultra quiet operation. With a one-head platform design and fewer mechanical parts, the reliability and acoustic features of the Spinpoint F4 have been improved. The drive delivers 10% increased read/write performance and 7% lower power consumption than the Spinpoint F1. The superior performance and high-reliability Spinpoint F4 is engineered for high-end computing in PCs, Macs, high-end workstations and server applications.
- Capacity: 320GB
- Cache: 16MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £32.99 Inc. VAT
Only £30.54 inc VAT.
ORDER NOW
Western Digital Caviar Black 640GB SATA 6Gb/s 64MB Cache - OEM (WD6402AAEX) @ £49.29 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
- Capacity: 640GB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Warranty: 5 Years
Was £53.99 Inc. VAT
Only £49.29 inc VAT.
ORDER NOW
Western Digital Caviar Blue 500GB SATA-II 16MB Cache - OEM (WD5000AAKS) @ £30.54 inc VAT
WD Caviar Blue hard drives are available with a multitude of available features to deliver rock solid performance and ultra-cool and quiet operation. Pick the drive that suits your needs with the confidence in knowing that all WD Caviar Blue drives are built to the highest standards of quality and reliability. These drives are the perfect solution for family and business computing.
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £31.98 Inc. VAT
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £72.99 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Was £79.99 Inc. VAT
Only £72.99 inc VAT.
ORDER NOW
Seagate Barracuda 7200.11 1.5TB SATA-II 32MB Cache - OEM (ST31500341AS) @ £54.29 inc VAT
Combining proven components and state-of-the-art technology, the Seagate Barracuda 7200.11 drive - the 11th generation of this award-winning desktop hard drive family - delivers high-performing, eco-friendly digital storage. Designed with industry-leading acoustics and power levels, and award-winning Seagate PMR technology, the Barracuda 7200.11 drive offers the ideal combination of world-class technology and lowest total cost of ownership.
- Capacity: 1.5TB
- Cache: 32MB
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £57.99 Inc. VAT
Only £54.29 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) @ £29.99 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £34.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
LiteOn iHOS104-37 4x BD-ROM Drive (Black) - OEM @ £38.76 inc VAT
Lite-On BD-ROM drives offer the best solution for people who want to enjoy High Definition Blu-ray movies at an affordable cost. Besides Blu-ray movies, your current DVD and CD collections can also be played. Lite-OnBD-ROM drives are compatible with Blu-ray, DVD and CD formats to ensure optimal playback possibilities. The iHOS104 comes with CyberLink TrueTheater software package. TrueTheater delivers the ultimate in movie playback quality for PC-based home theatre systems.
Read Speeds
- BD-ROM: 4x
- BD-RE: 4x
- BD-R DL: 4x
- BD-RE DL: 4x
- DVD+R/-R: 8x
- DVD+R/-R DL: 8x
- DVD+RW/-RW: 8x
- CD: 32x
Was £41.11 Inc. VAT
Only £38.76 inc VAT.
ORDER NOW
"Titan Krypt" AMD Athlon II X4 640 3.00GHz Quad Core DDR3 System @ £468.73 inc VAT
The "Titan Krypt" features a AMD Athlon II X4 Quad Core 640 3.00GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
Why Should You Buy This System?
- Includes the superb AMD Athlon II X4 640 3.00GHz Quad Core Processor
- Choose from a selection of graphics cards to meet your performance needs
- 4GB of high performance gaming memory guarantees the smoothest possible experience when multitasking and ensures you never have a break in the action
- Precision built and cabled by Overclockers UK expert technicians
System Specification
- Case: Antec 300 Three Hundred Ultimate Gaming Case - Black
- Power Supply: OCZ StealthXStream II 600W
- CPU: AMD Athlon II X4 Quad Core 640 3.00GHz Processor
- Motherboard: Asus M4A78LT-M 760G (AM3) Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9
- Hard Drives: Seagate Barracuda 1TB SATA-II 16MB Cache
- Graphics Card: Choice of the latest DirectX 10 and 11 graphic cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
If your after the latest in AMD technology then this system is for you. Based upon the 760G (AM3) chipset it offers full USB 3.0 support and SATA 6GB/sec ensuring your system is always up to date. Play and see games the way they are meant to be played.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
The lead time on all pre-built systems is between 24-48 hours.
Was £492.23 Inc. VAT
Only £468.73 inc VAT.
ORDER NOW
"Titan Predator" Intel Core i3 530 2.93GHz @ 4.20GHz ATI Edition DDR3 System @ £754.98 inc VAT
The "Titan Predator" features a Intel i3 530 2.93GHz processor overclocked and guaranteed to a stable 4.20GHz, combined with a selection of high performance, handpicked components placed into an Antec 300 gaming case with ATI Red fans to give it a unique look and feel. Experience a true DX11 experience with ATI Radeon graphics.
Why You Should Buy This System
- A guaranteed 4.20GHz performance for the price of 2.93GHz
- Case: Antec 300 Case with ATI red case fans.
- Power Supply: Corsair TX 650W
- CPU: Intel Core i3 530 2.93GHz Clarkdale overclocked to 4.20GHz
- Motherboard: Gigabyte H55M-UDH2 Intel H55 (Socket 1156) PCI-Express DDR3 Motherboard
- Cooler: Akasa Nero S CPU Cooler
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Hard Drive: Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
- Graphics Card: ATI DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Featuring a 4.20GHz overclock and utilising the latest ATI Radeon HD5000 Series of graphics cards, the "Titan Predator" is the ultimate hunter.
Was £766.73 Inc. VAT
Only £754.98 inc VAT.
ORDER NOW
"Ultima Viper" Intel Core i7 950 3.06GHz @ 4.00GHz DDR3 System @ £925.49 inc VAT
The "Ultima Viper" features a Intel i7 950 3.06GHz processor overclocked and guaranteed to a stable 4.00GHz, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
- A guaranteed 4.00GHz performance for the price of 3.06GHz
- 6GB of 1600MHz DDR3 Triple Channel memory allows faster loading of games and better multi-tasking
- Case: Antec 902 Ultimate Gaming Case - Black
- Power Supply: Corsair TX 650W ATX SLi Compliant Power Supply
- CPU: Intel Core i7 950 3.06GHz Overclocked to 4.00GHz
- Motherboard: Gigabyte EX58A-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
- Cooler: Prolimatech Megahalems Rev B CPU Cooler with Akasa Viper 120mm Fan
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
- Graphics Card: Choice of the latest graphics cards
- Sound: Realtek ALC889 7.1 Channel Sound (On-Board)
Service Package
Do you always want more? Do you want to be at the top of your game? Having the fastest system for a great gaming experience is now just a click away. This system is designed and built for gamers, by gamers.
Was £960.74 Inc. VAT
Only £925.49 inc VAT.
ORDER NOW
"Primo Ignition" Intel Core i3 530 2.93GHz DDR3 System @ £299.74 inc VAT
The "Primo Ignition" features a Intel Core i3 530 2.93GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
Why You Should Buy This System?
- Intel Core i3 530 2.93GHz (Clarkdale) Processer with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK Hades Case
- Power Supply: OcUK 450W
- CPU: Intel Core i3 530 2.93GHz (Clarkdale)
- Motherboard: Gigabyte GA-H55M-S2 Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo Ignition" is perfect for the user looking for a highperformance system for a low price.
Was £334.99 Inc. VAT
Only £299.74 inc VAT.
ORDER NOW
Argon Extreme Intel Core i3 2.93GHz @ 4.20GHz Overclocked Bundle @ £252.48 inc VAT
Designed by experts the "Argon Extreme Intel Core i3 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.20GHz overclock has the processing power and speed to power through the latest games with ease. The "Argon Extreme Intel Core i3 Bundle" offers superb gaming performance at an excellent price.
Why You Should Buy This Bundle?
- A solid, optimised 4.20GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
Bundle Specification
- CPU: Intel Core i3 2.93GHz @ 4.20GHz
- Motherboard: Gigabyte GA-H55M-UD2H (Socket 1156) DDR3 Motherboard
- Cooler: Artic Cooling Freezer 7 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £275.98 Inc. VAT
Only £252.48 inc VAT.
ORDER NOW
Krypton Intel Core i7 950 3.06GHz @ 4.00GHz USB3 Overclocked Bundle @ £536.49 inc VAT
Designed by experts the "Krypton Intel Core i7 950 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- USB 3.0 compatible offering lightning fast transfer speeds
- CPU: Intel Core i7 950 3.06GHz @ 4.00GHz
- Motherboard: Gigabyte GA-X58-USB3 (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Artic Cooling MX-3 Thermal Compound
Service Package
Was £559.99 Inc. VAT
Only £536.49 inc VAT.
ORDER NOW
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard @ £144.11 inc VAT
This motherboard supports the latest Intel Core i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. The P6X58D-E breaks the boundaries to bring you the multi-GPU choice of either SLI or CrossFireX. The motherboard features a dedicated graphics engine on the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems. Experience ultra-fast data transfers at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components. 16+2 phase power design, 16-phase for vCore and extra 2-phase for QPI/Memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability.
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express
- Memory: 6x DDR3 DIMM 2000(OC) / 1600 / 1333 / 1066 MHz (Max. 24GB) / Triple Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 3x PCIe 2.0 x16 Slots, 1x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 6x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x SATA 6Gb/s
- LAN: Marvell 88E8056 Gigabit LAN
- Audio: ALC889 8-channel High Definition Audio CODEC
- 8x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- 1x S/PDIF Out (Optical)
- 1x S/PDIF Out (Coaxial)
- 16+2 Phase Power Design
- TurboV
- MemOK!
- EPU
- Express Gate
- Fanless Design
- Stack Cool3+
- CrashFree BIOS 3
- EZ Flash 2
- MyLogo 2
Was £149.99 Inc. VAT
Only £144.11 inc VAT.
ORDER NOW
Gigabyte GA-P55A-UD6 Intel P55 (Socket 1156) DDR3 Motherboard @ £143.24 inc VAT
The P55A-UD6 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the Gigabyte 333 onboard acceleration technologies. Featuring the world's first USB 3.0 logo certified host controller from NEC Electronics, P55A-UD6 allows users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution, the Marvell 88SE9128 controller, Gigabyte P55A-series motherboards offer support for next generation high speed data storage devices with data transfer speeds of up to 6Gb/s. Coupled with RAID 0 (Stripe) mode, SATA Revision 3.0 enables a data transfer boost of up to 4x the speed of SATA Revision 2.0. The P55A-UD6 introduces a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
- CPU: Intel Core i7/Core i5 Processors (Socket LGA1156)
- Chipset: Intel P55 Express
- Memory: 6x DDR3 DIMM 2600+ / 2200 / 1333 / 1066 / 800 MHz (Max. 16GB) / Dual Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 3x PCIe 2.0 x16 Slots, 2x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 6x SATA 3Gb/s (RAID 0, 1, 5 and 10), 2x SATA 6Gb/s (RAID 0) & 2x eSATA 3Gb/s
- LAN: Dual RTL8111D Gigabit LAN
- 12x USB 2.0
- 2x USB 3.0/2.0
- 3x IEEE 1394a
- 1x PS/2 COMBO (Keyboard & Mouse)
- 24+2 Phase Design
- 2oz Copper PCB
- Smart6 (QuickBoot, QuickBoost, Recovery, DualBIOS, Recorder & TimeLock)
- Dynamic Energy Saver 2
- Smart TPM
- XHD (eXtreme HardDrive)
- AutoGreen
Was £154.99 Inc. VAT
Only £143.24 inc VAT.
ORDER NOW
Asus Crosshair IV Formula AMD 890FX (Socket AM3) DDR3 Motherboard @ £158.24 inc VAT
This motherboard supports AMD Socket AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 1333 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport 3.0 based system bus. This motherboard also supports AMD CPUs in the new 45nm manufacturing process.
- CPU: AMD Phenom II/Athlon II/Sempron 100 Series Processors (Socket AM3)
- Chipset: AMD 890FX / SB850
- System Bus: Up to 5200 MT/s HyperTransport 3.0
- Memory: 4x DDR3 DIMM 2000(OC) / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Expasion slots: 3x PCIe 2.0 x16 Slots, 1x PCIe x4 Slot & 2x PCI Slots (Supports ATI CrossFireX Technology)
- Storage: 6x SATA 6Gb/s (RAID 0, 1, 5 and 10), 1x SATA 3Gb/s & 1x eSATA 3Gb/s
- LAN: Marvell 8059 Gigabit LAN
- Audio: SupremeFX X-Fi 8-channel High Definition Audio CODEC
- 12x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 8+2 Power Phase
- Core Unlocker
- Turbo Key II
- TurboV EVO
- EPU
- MemOK!
- Game First
- CPU Level Up
Was £169.99 Inc. VAT
Only £158.24 inc VAT.
ORDER NOW
Asus Crosshair III Formula AMD 790FX (Socket AM3) PCI-Express DDR3 Motherboard @ £96.44 inc VAT
The Crosshair III Motherboard supports the latest AMD Socket AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption providing you with more power and cheaper running costs. The AMD 790FX Chipset is designed to run up to 5200MT/s HyperTransport 3.0 interface speed and quad PCI Express 2.0 x16 graphics. It is optimized with AMD's latest AM3 and multi-core CPUs to provide excellent system performance and overclocking capabilities. Native DDR3 1600(O.C.) support provides faster data transfer rate and more bandwith to increase memory computing efficiency, enhancing system performance in 3D graphics and other memory demanding applications.
- AMD Socket AM3 (Phenom II/Athlon II/Sempron 100 Series Processors)
- AMD 140W CPU Support
- AMD Cool 'n' Quiet Technology
- Supports 45nm CPU
- AMD 790FX/SB750
- Up to 5200 MT/s; HyperTransport 3.0
- 4 x DIMM, Max. 16 GB, DDR3 1600(OC)/1333/1066
- 2 x PCIe 2.0 x16
- 3 x PCIe 2.0 x1
- 1 x PCI 2.2
- Gigabit LAN controller, featuring AI NET 2
- SupremeFX X-Fi Audio Card
- 2 x 1394a ports
- 12x USB 2.0 ports
- Asus MyLogo 3
- Asus EZ Flash 2
- Asus CrashFree BIOS 3
- Q-Connector
- Asus Q-Fan 2
- External LCD Poster
- Asus Q-Shield
- AMD OverDrive Support
- Asus TurboV
Was £105.84 Inc. VAT
Only £96.44 inc VAT.
ORDER NOW
Asus Xonar DX 7.1 PCI-Express Sound Card @ £54.99 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscape has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar DX driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar DX audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 116dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar DX is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Unprecedented SSNR NR Up to 116db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Legally backup your digital music into non-protected MP3/WMA files with even better quality and Dolby Headphone and Virtual Speaker effects
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Low Profile Bracket Included
- Vista Ready
Was £56.99 Inc. VAT
Only £54.99 inc VAT.
ORDER NOW
Asus CineVibe Rumble Feedback USB Gaming Headset @ £38.76 inc VAT
Immerse yourself. Feel every glancing blow and get yourself in the game like never before. The ASUS CineVibe is here and brings tactile bass vibration to a level never found before to give you that competitive edge. With ASUS audio engineering at the heart of the CineVibe, there really has never been a headset like this. The CineVibe is a plug & play USB headset that delivers the full audio package without the need for pesky driver installation. Comfort and precision are the most important aspects of any gaming headset and the gamers spirit is captured here - Shoot first and ask questions later because with CineVibe, there are no points for second place.
- USB Plug & Play - No drivers needed!
- Tactile Vibrations - Get yourself in the game!
- Volume, Microphone and Vibration control - Adjust volume, microphone mute and vibration on or off at the flick of a switch!
- Fold Flat Design - Easy to transport to LANs!
- Directional Noise Cancelling Microphone - Clear communication is the key to victory!
Was £39.99 Inc. VAT
ORDER NOW
Logitech G35 7.1 Surround Sound Headset (981-000117) @ £77.41 inc VAT
The Logitech G35 headset. Game-changing immersion with 7.1 surround sound powered by Dolby technology for a detailed soundfield - hear your enemies before they see you. Featuring three swappable headband pads so you can choose the best fit, for long-lasting comfort; three customizable G keys for one-touch command over music, voice morphing, and more; on-ear audio controls for quick access to volume, microphone mute, and surround sound adjustments; and an adjustable, noise-canceling microphone that focuses on your voice and reduces background noise.
- 7.1 surround sound powered by Dolby technology delivers a detailed soundfield - hear your enemies before they see you.
- Three swappable headband pads let you choose the best fit, for long-lasting comfort.
- Three customizable G keys give you one-touch command over music, voice morphing, and more.
- On-ear audio controls provide quick access to volume, microphone mute, and surround sound adjustments.
- Adjustable, noise-canceling microphone focuses on your voice and reduces background noise.
Was £79.99 Inc. VAT
Only £77.41 inc VAT.
ORDER NOW
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) @ £34.06 inc VAT
Venom, this cooler is definitely rock and roll. Venom delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.
The Black cover and nickel plated heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Four high capacity 8mm heatpipes with direct CPU contact provide rapid heat transfer from CPU to 45 aluminium fins. Anti-vibration rubber fan mounting pins provide easy installation and help to elimate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.
The Smart cooler design allows for the installation of a second fan, giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.
- Dimensions: 120 (W) x 96 (D) x 160 (H) mm
- Fan speed: 600-1900 RPM (PWM controlled)
- Max airflow: 83.63 CFM
- Noise level: 6.9 - 28.9 dB(A)
- Performance 12cm PWM fan in killer Viper yellow
- 4 high capacity 8mm heatpipes with direct CPU contact
- Award winning S-FLOW fan blades provide 30% more airflow
- Smart design allows for a 2nd fan for extreme performance
- Rubber fan mounts for easy installation and quiet performance
Was £35.99 Inc. VAT
Only £34.06 inc VAT.
ORDER NOW
Titan Fenrir Evo CPU Cooler (Socket LGA775/LGA1156/LGA1366/AMD K8/AM2/AM2+/AM3) @ £32.89 inc VAT
Compare with the 1st version, the FENRIR EVO, TTC-NK85TZ/CS2 (RB), features a powerful fan with nine kukri-shaped blades for maintaining a lower noise level at 15dBA only. It is highly recommended to the gamers looking for overclocking potential and an improved hushed operation. The all-in-one socket support is compatible with most Intel and AMD systems.
The War Machine, FENRIR EVO, utilizes unique plating technology to create dual-color gradation of heatsink allowing you to build your own cooling platform.
- 4 x 8mm heatpipes with Heat Pipe Direct Contact feature: for rapider heat conductivity
- 12cm ultra-silent fan with nine kukri-shaped blades
- Newly revamped fan is perfect for comprehensive cooling capacity and extremely noiseless operation at 15 dBA only
- PWM intelligent fan controller: provides an excellent balance between high and low speed
- High density fin design: large surface for heat dissipation while overclocking
- All-in-one socket support: compatible with Intel LGA 775/LGA1156/LGA1366 and AMD K8/AM2/AM2+/AM3 systems
Was £35.99 Inc. VAT
Only £32.89 inc VAT.
ORDER NOW
Corsair Professional Series™ Gold AX1200 High Performance 1200W Power Supply (CMPSU-1200AXUK) @ £223.24 inc VAT
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you. All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it’s time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling — the cables stay in place and connect to your new fully-modular Corsair power supply. With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It’s earned the 80 Plus® Gold seal of approval, your guarantee that you’re making the right choice for smart, efficient power delivery.
- Supports the latest ATX12V v2.31 and EPS 2.92 standards and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80 Plus Gold certified to deliver at least 90% efficiency at 50% load
- Active Power Factor Correction (PFC) with PF value of 0.99
- A dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- High-quality Japanese capacitors provide uncompromised performance and reliability
- Completely modular cable system allows you to use only the cables you need
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis
- A seven year warranty and lifetime access to Corsair’s legendary technical support and customer service
- Dimensions: 150mm(W) x 86mm(H) x 200mm(L)
- MTBF: 100,000 hours
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
- Seven Year Warranty
Was £234.98 Inc. VAT
Only £223.24 inc VAT.
ORDER NOW
OcUK Swift 450W Silent Power Supply @ £12.91 inc VAT
The OcUK swift power supply is sourced and built from high quality components making these reliable power supplies for anyone who is building a home or office computer. They feature a 120mm fan for low noise operation keep the whole PC quiet. These units offer incredible value for money and are ideal for any PC used in the home or office.
- AC input Voltage: 95-132VAC or 190-264 VAC switchable
- AC input Frequency:50HZ/60HZ
- AC input Current:10A res max. for 115VAC, 5A res max. for 230VAC
- Ripple-noise:5A res max. for 230VAC
- Operation temperature:0oC ~+40oC
- Hold up time :16ms
- Dielectric withstand:Input to frame ground 1800VAC for 1 second
- Power good signal:Power on delay time 100ms to 500ms
- Ppower fail :oC>=1ms
- Overload protection :150%
- Universal 20+4 Pin Main ATX Power Connector X 1
- 4 Pin + 12V Power Connector X 1
- Peripheral Connector (4Pin for HDD, CD ROM…etc) X 4
- Floppy Connector (4 Pin) X 1
- Latest L-Type Serial ATA Power Connector X 1
Was £17.99 Inc. VAT
Only £12.91 inc VAT.
ORDER NOW
Logitech G700 Wireless Gaming Mouse (910-001759) @ £69.98 inc VAT
The Logitech® Wireless Gaming Mouse G700 keeps you comfortable, in control and deep into your game. Its 13 programmable G-Keys can be used to perform single actions or complex macros with a single click. The natural curves fit your hand for epic levels of comfort, so you can keep at it for as long as you want. And its full-speed wireless connection gives you gaming-grade performance coupled with wireless freedom. It comes with a quick-connect cable that charges your mouse and can transmit data over the cable. When your guild gets together, you'll have all the control you need to do battle, complete quests and level up your character. Logitech® SetPoint™ software required for initial setup and is available at logitech.com/downloads.
- 13 individually sculpted, programmable G-Keys let you perform either single actions or intricate macros with multiple keystrokes, mouse events, user-defined keys and repeating. No matter what your game, you'll get deep into it. You have the control you need to play better. To conquer more. To win.
- With natural curves that fit your hand, you get epic levels of comfort, while smooth-gliding feet let you manoeuvre effortlessly. You'll play comfortably, without distraction, for as long as you want.
- Full-speed wireless (1,000 reports per second) helps eliminate lag so you enjoy gaming-grade responsiveness and wireless freedom. You get a steady, powerful connection with no dropouts.
- A quick-connect cable for recharging and data transfer lets you plug in fast and continue your campaign without pause. You'll never run out of power. And you'll always have a backup for reliable connectivity.
- You get a mouse that's crafted just for gaming. The gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you store up to five profiles*. And the dual-mode scroll wheel can switch from click-to-click for weapon selection to free spinning for hyper-fast scrolling.
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £123.36 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £128.98 Inc. VAT
Only £123.36 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz (Socket AM3) - Retail @ £199.98 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Multiplier Unlocked
- Six Core Technology
- 3.20GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £224.99 Inc. VAT
Only £199.98 inc VAT.
ORDER NOW
AMD Athlon II X4 Quad Core 630 2.80GHz (Socket AM3) - Retail @ £69.31 inc VAT
At home or at play, AMD Athlon II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Quad Core Technology
- 2.80GHz Clock Speed
- AM3 Socket
- 2MB L2 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £75.19 Inc. VAT
Only £69.31 inc VAT.
ORDER NOW
OCZ Reaper 6GB (3x2GB) DDR3 16000C9 2000MHz Triple Channel Kit (OCZ3RPR2000LV6GK) @ £111.61 inc VAT
The OCZ Reaper HPC PC3-16000 triple-channel memory kits are designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset, the ideal memory kit for enthusiasts demanding the most from their performance systems. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, blazing speed, and latency.
The Reaper HPC Series makes use of an innovative cooling solution to more effectively dissipate heat produced by high-speed memory, and offers superior cooling technology to ensure superior stability and performance over the entire life of the memory. The thermo-conductive copper heat pipe conduit is ideal for overclocking where every degree matters, ensuring that your cutting-edge investment will maintain its integrity throughout the toughest gaming missions, overclocking, or intense program applications.
Developed for enthusiasts who aren't afraid to overclock, the low voltage Reaper Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility.
OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- CL 9-9-9-30 (CAS-TRCD-TRP-TRAS)
- Reaper HPC Heatspreader
- Lifetime Warranty
- 1.65 Volts
Only £111.61 inc VAT.
ORDER NOW
Corsair XMS3 6GB (3x2GB) DDR3 12800C9 1600MHz Triple Channel (CMX6GX3M3A1600C9) @ £99.99 inc VAT
The XMS Series CMX6GX3M3A1600C9 is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.65V VDIMM.
- Each three module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.65V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.65V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Was £104.99 Inc. VAT
Only £99.99 inc VAT.
ORDER NOW
Patriot Viper 2 Sector 5 4GB (2x2GB) PC3-20000C9 2400MHz Dual Channel Memory Kit @ £117.49 inc VAT
The Patriot Viper II Series, 'Sector 5' Edition, part of the Extreme Performance (EP) Enhanced Latency line, is the ultimate performance memory solution for the Intel® P55 system platform. The Viper II Series, 'Sector 5' Edition is built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the P55 platform to achieve optimized performance and maximum quality. These modules are engineered to reach PC3-20000 (2400MHz) at 9-11-9-27 timings and are available in 4GB kit capacity. Each module is 100% hand-tested for quality assurance and is backed by a full lifetime warranty and industry leading customer service.
Features
- Extreme Performance PC3-20000 (2400MHz)
- Low Latency (9-11-9-27)
- 1.65V
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- Lifetime Warranty
- XMP Ready for Core i7 Processors
Only £117.49 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £61.09 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Was £65.99 Inc. VAT
Only £61.09 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3G1600LV4GK) @ £68.14 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1600MHz. Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops. OCZ DDR3 PC3-12800 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1600MHz DDR3
- CL 8-8-8-24
- Available in 4GB optimized kits
- Unbuffered
- Gold Layered Z3 XTC Heatspreader*
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Was £76.36 Inc. VAT
Only £68.14 inc VAT.
ORDER NOW
Patriot Viper 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (PVS34G1600LLK) @ £61.09 inc VAT
Patriot Extreme Performance (EP) Low Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 7-7-7-20 timings and is available in 4GB kit capacity. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (7-7-7-20)
- 1.7-1.9v required for 1600MHz 7-7-7-20 operation
- 100% Tested and Verified for AMD and Intel P35/X38 setups
- Lifetime Warranty
- RoHS Compliant
- XMP Ready
Was £69.99 Inc. VAT
ORDER NOW
Gigabyte GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card with MAFIA 2 @ £334.86 inc VAT
Next generation gaming has arrived. Nvidia GeForce GTX 480 gives your games an adrenaline shot with the world's fastest performance and futuristic, visually stunning graphics. Experience heartpounding, cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jawdropping stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 480: pure adrenaline meets visual bliss.
- Core Clock: 700MHz
- Memory: 1536MB GDDR5
- Memory Clock: 3696MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 480
- Shader Clock: 1401MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Supplied with HDMI Cable
- Warranty: 3 Years
- Supplied with Full Mafia 2 PC Game as of 27/08/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
Was £352.49 Inc. VAT
Only £334.86 inc VAT.
ORDER NOW
Gainward GeForce GTX 460 GS 1024MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £149.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 700Mhz
- Memory: 1024MB GDDR5
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1400MHz
- Display Connectors: 2x Dual-Link DVI-I & 1xHDMI & 1 X Analogue
- SLI Ready
- HDCP Capable
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
- Supplied with Full TOM CLANCY's HAWX2 PC Game as of 18/10/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
Only £149.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 460 OC 768MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £124.98 inc VAT
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
The special inclined dual fan design effectively minimizes the flow of turbulence between two fans and enhances heat dissipation of hot area right underneath each fan. By unique design, WINDFORCETM 2X even enlarges air channel on the graphics card vents and creates a more effective air flow system in chassis. This special design helps heat dissipate quickly from GPU. In addition, WINDFORCETM 2X is equipped with 2 copper heat-pipes which strengthen the speed of heat dissipation.
Features
- Core Clock: 715Mhz
- Memory: 768MB GDDR5
- Shader Clock: 1430MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £129.99 Inc. VAT
Only £124.98 inc VAT.
ORDER NOW
Gigabyte GeForce GTS 450 OC 1024MB GDDR5 PCI-Express Graphics Card with FREE Mouse Pad & HAWX2 PC-Game @ £99.99 inc VAT
Designed with unparalleled levels of price/performance and more than 2x the DirectX 11 geometry processing power over competing GPUs, NVIDIA GeForce GTS 450 dominates the competition and offers amazing game realism on the latest DirectX 11 titles like Civilization V. Equipped with the latest industry leading technologies including NVIDIA 3D Vision, NVIDIA PhysX, high performance NVIDIA GeForce drivers, and more, GeForce GTS 450 has everything you need to spoil your senses.
- Core Clock: 830MHz
- Memory Clock: 3608MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 192
- Shader Clock: 1660MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini HDMI 1.4a
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £107.99 Inc. VAT
ORDER NOW
HIS ATI Radeon HD 5830 1024MB GDDR5 PCI-Express Graphics Card @ £146.86 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5830 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 800MHz
- Memory Clock: 4000MHz (Effective)
- Processing Cores: 1120
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
- Includes Call Of Duty: Modern Warfare 2 & Napoleon Voucher Codes
Only £146.86 inc VAT.
ORDER NOW
HIS IceQ 5 Turbo ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card @ £111.61 inc VAT
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
HIS IceQ 5 technology is endorsed as the most efficient cooling technology among the current mainstream graphic cards' series. HIS IceQ 5 can actively draw the air inside your PC case to cool down the card, and blows amounts of hot air out of your case, dramatically decreasing the GPU temperature together with your PC components.
- Core Clock: 875MHz
- Memory Clock:5000MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Year
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £99.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
ORDER NOW
Iiyama ProLite E2208HDD 22" Widescreen LCD Monitor - Black @ £111.61 inc VAT
The ProLite E2208HDD Widescreen LCD features true High Definition, 16:9, 1920 x 1080 pixels as its native resolution. Impressive colour reproduction is achieved with a typical contrast ratio of 1000:1 with the User Option to enhance further with Advanced Contrast Ratio enabled for 10000:1. 'Opticolour' automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity.
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 516.5mm x 386.0mm x 193.0mm
- Weight: 4.2kg
- Warranty: 3 Years On-Site
Was £114.99 Inc. VAT
ORDER NOW
LG Flatron W2261V-PF 22" Widescreen LCD Monitor - Black @ £140.99 inc VAT
Gamers and movie buffs will love this widescreen LCD monitor. LG’s FLATRON f-ENGINE picture-enhancing chip offers enhanced image definition, smooth motion, and superb colour reproduction, making it ideal for watching films. And, with a 2ms response time, your video games will look better than ever. A single, all-digital cable input makes it easy to connect and integrate all your digital systems, including cable/satellite boxes and games.
- Contrast Ratio: 50000:1
- Response Time: 2ms
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 519.0mm x 387.0mm x 193.0mm
- Weight: 4.2kg
Was £146.86 Inc. VAT
Only £140.99 inc VAT.
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £164.49 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Was £170.36 Inc. VAT
Only £164.49 inc VAT.
ORDER NOW
Iiyama ProLite E2410HDSD 24" Widescreen LCD Monitor - Black @ £146.86 inc VAT
The new ProLite E2410HDSD-1 is the new 24” screen size to join the iiyama Eco-monitor range. Energy Star rated and using less than 1W in power management mode it is good for the environment yet still features the high specification you come to expect from iiyama. Combining an exceptionally fast 2ms response time, true 16:9 HD and 1920x1080 (2.1mega pixel) native resolution makes for improved colour range and depth in gaming and video and graphic applications. The E2410HDSD features 2 x 2W speakers and analogue and digital connectivity for flexibility across different platforms.
Features:-
- Contrast Ratio: 20000:1
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 4.5kg
Was £152.74 Inc. VAT
ORDER NOW
Samsung P2450H 24" Widescreen LCD Monitor - Glossy Black @ £169.99 inc VAT
Film fans and gamers will love the Samsung SyncMaster P2450H TFT display! The Samsung P2450H is a 24 widescreen monitor that willplunge you into all your favourite films and 3D games with breathtakingly realisticresults. The P2450H has a fantastic contrastratio for deep blacks and rich colours. Plus, the P2450H has aresponse time of just 2 ms which is great for online games! Plus, the Samsung SyncMaster 2450H has a wide selectionof connections, including an HDMI port for hooking up a HD games console orcamcorder.
- Contrast Ratio: 70000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 578.0mm x 430.0mm x 190.0mm
- Weight: 5.4kg
Was £179.99 Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
MSI GT640 15.4" WLED TFT Intel I7-720QM, 4GB DDR3, 640GB HDD, NVIDIA GTS 250M 1GB GDDR3 Graphics Card, Win7 Home Premium 32-Bit - Black/Red @ £791.94 inc VAT
nonl2br
<font size="4"><b>Key Features</b></font><br>
<br>
- The latest Intel® Core™ i7 Processor (I7-720QM 1.60GHz (2.80GHz Turbo Mode)<br>
- Genuine W-indows® 7 Home Premium<br>
- Exclusive ECO Engine Power Management System<br>
- Exclusive Cinema Pro Technology<br>
- Housing combines aluminum alloy construction and brushed metal texturing<br>
- High-end nVIDIA GeForce GTS 250M discrete graphics card (with DDR3 1GB VRAM)<br>
- Digital/analog 7.1-channel headphone output qualified by SRS Premium Sound<br>
- HDMI (High-Definition Multimedia Interface) Output<br>
- Built-in 2.0 Mega Pixel Webcam<br>
- 802.11 b/g/draft-n Wireless LAN with Bluetooth<br>
<br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt640/gt640_03.jpg" align="left" alt="Gt640" /><img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt740/gt740_02.jpg" align="right" alt="Gt640" />
<font size="4" color="blue"><b>The Latest Intel Core i7 Processor</b></font><br>
<br>
The GT640 uses the most advanced Intel Core i7 processor, and is the world’s performance leader among gaming laptops, giving users the ultimate experience in speed.<br>
<br>
<br>
<font size="4" color="blue"><b>MSI's exclusive ECO Engine power management system</b></font><br>
<br>
The GT640 takes advantage of the ECO Engine power management system, allowing users to select from five different usage scenarios—text processing, gaming, movie viewing, presentations, and Turbo Battery modes—and instantly obtain optimized settings for screen brightness and sleep, automatic system sleep activation, and processor performance<br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt640/gt640_05.jpg" align="centre" alt="Gt640" /><br>
<br>
<br>
<font size="4" color="blue"><b>Sleek brushed-metal design</b></font><br>
<br>
<b>Housing combines aluminum alloy construction and brushed metal texturing</b><br>
The GT640 weighs just 2.7 kilograms (including battery), making it easier to carry than other 15.4” gaming notebooks in the market<Br>
<br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt640/gt640_07.jpg" align="centre" alt="Gt640" /><br>
<b>Contoured touch-style hotkeys</b><br>
The GT640 uses all-new touch-sensitive hotkeys, with a housing sheathed in a glossy black finish, and no extraneous ornaments to clutter its sleek looks. <br>
<br>
<b>Highlighted W, A, S, D keys made for gaming</b><br>
Gamers can find the direction keys as quickly as possible when the action gets hot and heavy, giving them an edge when fractions of a second matter. <br>
<br>
<br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt640/gt640_11.jpg" align="right" alt="Gt640" />
<font size="4" color="blue"><b>Enjoy sight and sound like you’re there as it happens</b></font><br>
<br>
<b>High-end nVIDIA Geforce GTS 250M 3D discrete graphics card (with DDR3 1GB VRAM) </b><br>
When you’re gaming, the incredibly fluid, exquisitely crisp, ultra-realistic rendering of even the most complex and dynamic 3D scenes will make for an immersive experience at a whole new level! <br>
<br>
<br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt640/gt640_12.jpg" align="left" alt="Gt640" /><br>
<br>
<br>
<b>Digital/analog 7.1-channel S/PDIF output</b> <br>
The SRS Premium Sound™-certified audio performance, and built-in digital/analog 7.1-channel S/PDIF output ensure you get an utterly captivating aural experience. <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><b>Specification</b></font><br>
<br>
- Intel Core I7 720 Quad Core 1.60GHz (8 Threads)<br>
- 1.60GHz Clock Speed (Turbo Boost supported upto 2.80GHz)<br>
- 4GB DDR3 1066MHz Ram (2x2GB)<br>
- 15.4" WSXGA+ 1680x1050 Resolution LED Screen<br>
- NVIDIA GeForce GTS 250M 1GB VRAM Graphics Card<br>
- 640GB Western Digital HDD<br>
- Blu-Ray DVD-Combo Player<br>
- Wirless N & Bluetooth Connectivity<br>
- 6 Cell Battery (Upto 3.5hrs battery life)<br>
- Digital Webcam<br>
Was £799.99 Inc. VAT
Only £791.94 inc VAT.
ORDER NOW
Samsung R730 17.3" LED Intel Dual Core T4300, 4GB RAM, 320GB HDD, DVD-RW, Win7 Home Premium - Open Box @ £393.61 inc VAT
If you want a laptop that will deliver top-drawer performance without the top-drawer price tag, then take a look at the Samsung R730. It’s powerful, and it won’t empty your pocket.
If you’re into music and movies, or you want to multitask all your favourite applications without your laptop lagging behind then the R730 is for you. It’s got a powerful Pentium Dual Core processor alongside a huge 4GB RAM, so it’ll make light work of your heaviest tasks; it’s ideal for students and home users who want a machine that covers every base.
Great performance is nothing without great visuals to match and the R730 definitely doesn’t disappoint. The stunning 17.3” high-definition LED screen turns this laptop into your own portable cinema. Wherever you go, you can enjoy your favourite films in unprecedented detail; sit back, relax, and enjoy.
When the movie’s done and you fancy some music, the R730 will continue to impress. The SRS 3D Sound technology will give your songs a whole extra edge, and the massive 320GB hard drive will ensure you’re never struggling with space to store them.
Samsung understand that in today’s modern digital world, the connectivity of your laptop is key. The R730 comes with a HDMI port, so you can hook it straight up to your big screen TV and use that as your monitor. It’s got wireless technology and an integrated webcam too, so you’ll never be more than a few clicks away from your online social life.
Inject your life with some Samsung style, and enjoy amazing power at an affordable price, with the Samsung R730 laptop.
Features:-
- Intel Pentium Dual Core T4300 2.1GHz (Dual Core)
- 4GB DDR3 SDRAM - 1066 MHz
- 17.3" Superbright LCD
- 320GB HDD
- 17.3' TFT 1600 x 900
- DVD±RW (+R double layer) / DVD-RAM Optical Drive
- Intel GMA X4500 Dynamic Video Memory Technology 5.0 Graphics
- Integrated Webcam
- Microsoft Windows 7 Home Premium
- 6 Cell Battery (upto 4hrs battery life)
- 2.84kg weight
- HDMI Port
-12 Month Warranty - Open Box
Was £399.49 Inc. VAT
Only £393.61 inc VAT.
ORDER NOW
Acer Aspire Timeline 1810TZ Ultra Thin 11.6" WLED TFT, Intel SU4100, 3GB RAM, 250GB HDD, Win7 Home Premium - Red @ £349.99 inc VAT
If you want a great mobile laptop that keeps the environment in mind then the Acer Timeline 1810TZ could be for you.
Acer are befriending the planet with their new series of energy-conscious notebooks, offering reduced power consumption to give you upwards of 6 hours battery life from one charge. Because they know you’ll be leaving your socket behind and getting on the go they’ve made the 1810TZ ultra-thin too; it’s lean and it’s green.
Even though you’re saving the planet you won’t be saving on performance because the 1810TZ comes with a powerful low voltage Pentium Dual Core processor and a speedy 3GB RAM. Whether you’re dealing with your documents or sorting your spreadsheets you won’t be sitting around twiddling your fingers; the 1810TZ has more than enough oomph to keep you productive.
When it’s time for lunch and you need to save your progress you’ll have no trouble either because this laptop comes with a roomy 250GB hard drive, and it’ll probably be easier to keep tidy than your desk!
It’s the ideal laptop for the mobile businessman, giving you the power to get things done quickly along with the mobility to do them on the move. If the world is your office then the Timeline 1810TZ is your laptop.
Specification:-
- Screen size - 11.6inch LED - 1366 x 768
- Processor - Intel Pentium SU4100 - 1.3 GHz
- RAM - 3 GB
- Hard Drive - 250 GB
- Operating System - Microsoft Windows 7 Home Premium 64 bit
- Optical Drive - None
- Graphics - Intel GMA 4500MHD
- Webcam - Integrated
- 802.11b/g/Draft-N
- 6 Cell (Upto 6hr battery life)
- HDMI Output, Analogue Output, 3 USB Output, Headphone/Mic Outputs, Card Reader
- Warranty - 1 year warranty
Was £449.99 Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
[/IMG]http://overclockers.co.uk/pimg/LT-026-MS_400.jpg[/IMG]
nonl2br
<br>
<br>
<br>
<br>
<br>
Formatting fail :p
DO WANT AM3 Motherboards!
Would upgrading from a basic Gigabyte to a Asus Rampage MB make much difference?
(Use on-board sound as well so would that be better as well?)
Tempted by the F7D4402UK/F7D4401UK Play N+N/802.11n router.
Couple of questions:
-Do they support 802.11g? I don't have any equipment supporting 802.11n.
-Do they support ADSL2/ADSL2+?
Thanks
Just ordered the Acer 1810TZ - a comfort buy after a shoulder op on monday :D replacement for my old (but still alive and kicking) Advent Celeron sub-notebook from 2007.
Seems bargainous!
Would you prefer PC's built to order in a pumpkin?!
That'd be awesome, actually. When I clicked on this thread, I was hoping to find graphics cards being given away with L4D2, Dead Rising 2 or something remotely horror-ey... not deals that could happen at any time during the year and be called a respective season-y name.
"Great Martin Luther King Remembrance deals!"
I agree with this. I also don't see how they are Halloween deals, other than because they're on near/around/on Halloween.
Same was Christmas deals are Christmas deals because they are around Christmas time. You wouldn't expect Father Christmas to deliver them would you? :p.
Also, just ordered the Samsung 2Tb drive, drastically running out of storage space at the moment!
