Really? I very much doubt it - any benchmarks to back it up?
My 2.2ghz dualcore has never limited gaming and his is 3.6ghz and a better architecture...
Yep entirely serious
If you think I need to look at benchmarks, please link to them mate
I've done a fair bit of benchmarking myself and found increasing CPU and RAM speed did next to nothing to FPS, so I'm very hesitant to believe another 2 cores would do much
Going from an X1950XT to an 8800GTX gave me 2.5x the FPS in STALKER and roughly 2x in Crysis and Crysis Warhead.
OCing CPU from 2.2GHz 733MHz RAM to 2.6GHz 865MHz RAM did not even make a statistically significant difference in any of those games, we're talking going from 32 to 33 fps at high detail from a ~20% overclock
Yes that example is OCing as I have not owned a quad to test with, but dropping details from high to med to low (with Physics kept on Very High) resulted in large boosts in FPS each time, suggesting the bottleneck is absolutely the GPU and nothing else, and historically games have benefitted from clockspeed over more cores
Just found this - http://www.anandtech.com/show/3937/...thlon-ii-cpus-balance-price-and-performance/5
Low res presumably to remove GPU bottleneck, and a 3.3ghz dual beats a 3.1ghz quad, and only loses by 5fps to a hexacore
Dawn of War 2 and WoW both favouring clockspeed over cores on that same page
DAO, this one does seem to scale with cores, yet with a 2.8GHz dual getting > 60fps, I wouldn't call that a real-world example of holding back...as I wouldn't say going from 60 to 90fps is even noticable unless you have a 120hz monitor...even then...who knows
Not had much time to look, but couldn't find any CPU benchmarks of games at 1920x1200 with high details...my guess is because pretty much all CPUs blend into one result in that case
So yeah I very much doubt changing from 3.6GHz C2D to something higher would make any noticable difference, but the same cash added to gfx card budget...that would indeed
Isnt WOW extremely cpu dependant?
He'l still need an upgrade to his: ASUS 8800GTS 512
as I want to play the upcoming Cataclysm in full. I don't speak Dutch and don't have friends who know enough about PC's to help either
Rig:
*Edit* Corsair HX620 watt
ASUS P5Q-E
Intel E8400 @ 3.6ghz
4gb OCZ PC6400
ASUS 8800GTS 512
Windows XP 32bit
Really just looking for general advice on how to get the most out of my rig, my obvious thoughts are the GPU and Windows XP 32bit... Don't think I can be bothered upgrading to Windows 7 but if theres an outrage as to why I don't have it already I'll acquire a copy :]
Your system still looks decent TBH even with newer games. I would first try the game on your system to see how it runs first.
If you really want DX10 support for the game then getting a copy of Windows 7 Home Premium 64 bit would be a good idea.
Cataclysm is Dx11 no?
Also what Cat says I think is your best option.
See how the game runs on your system, and take it from there.
