Back to Battlefield BC2 - it actually has one of the more sophisticated gaming audio engines available - and has a dedicated headphone mode.
Dud just try various combinatiosn and see what works best for your setup.
I'v ementioned that I found after testing various options out that having CP on Hi-Fi gives me an excellent gaming experience on par with my X-Fi but without the drawbacks of GX3D where FRAPS doesn't work properly.
Match in game settings to channels for BC2.
Either headphone in game, 2 channels, hi fi mode
or surround in game (4.0 / 4.1, 5.1 or 7.1 matched to 4, 6 or 8 channel respectively) with Dolby Headphone and/or virtual speaker shifter.
I mention 4 channel as being worth a try as some game engines turn off some effects automatically for 5.1 or above.
Just for the record, I've not played BC2 but there are a few interesting articles online about it, including an interview with an Audio-programmer that worked on the game.
Edit: the above assumes you're using headphones. From reading around it would appear that the BC2 in game audio engine is designed for stereo or 5.1, 16 bit, 48khz so I would go with those
It's not really an annoyance when not using it results in comparable immersion as with the XFi though is it![]()
I rarely watch films alone but when I do, yes. DH1 or DH3 depending on how far I'm sitting from the screen.
I'm thinking of getting a D2X for my HTPC/gaming PC (also connecting to an Onkyo receiver). Are you guys connecting via HDMI, or analog?
If i 'do' just decide to use HDMI, will i still get proper multi-channel sound even if the game/source material isn't DTS/DD etc?
I recall having issues with my old receiver because I was connecting via Optical out, i'd only get multi channel sound if the source material was bitstreamed. If it was a game, i'd only get stereo![]()
HDMI from where? D2X doesn't have HDMI, unless you are thinking of the HDAV cards?
Interesting. I wondered if you used the same setting for films as well as music. DH2 is the only one I use. DH1 is too close, and DH3 is too distant and echoey. It's all down to taste and preference, but for me DH2 is just right.![]()
