Tongue Piercing
My cousin had his done.
Was a "hard" rock climber, didn't look gay in the slightest on him.
Did get infected though and was disgusting, wouldn't recommend it to anyone.
lol this is unbelievable. When I made a thread about ear studs, there were more 'gay' replies than in this thread about tongue piercing, which imo is actually gay.
Friend of mine in 6th form had her breast pierced, not nipple. breast.
A tube of metal the same length but half the width of a pencil straight through the centre meat.
Looked awesome to be honest but seemed a lot of hassle for something that could only be in for 24 hours or something daft.
Had it done and girls actually do like it, but i got fed up of it and the fact i swallowed the jewelry twice [bought two fyi] because it got loose sometimes when you eat and decided not to bother with it any longer.
If you want it, then get it done but after my experience due to consuming the jewelry, i would reconsider.
I have my tongue pierced. Most females I know love it. It's also a great ice breaker when out just running your stud over your lip it can start convos and what not. Normally if they give it "You have your tongue pierced ;)" then I continue on with the good old "You don't even want to know what else I have done...." Hook line and sinker!
I've had mine in for 9 years. Never once had the ball come undone, I tightened it up so much that bad boy isn't coming out. Have to be careful when sparring at MMA though -.-
I have my tongue pierced. Most females I know love it. It's also a great ice breaker when out just running your stud over your tongue it can start convos and what not. Normally if they give it "You have your tongue pierced ;)" then I continue on with the good old "You don't even want to know what else I have done...." Hook line and sinker!
deep
