- 17 Oct 2003
- Dublin
lo all - longish post, so please bear with me...
im about to get an nvidia gtx 460 1gb, and i suspect my psu may not be up to it. because i am a cheap git at the best of times, im going to run a second power supply (as I have one spare) to help matters.
if i have my wiring diagrams right, i'll need the green and any black wire from the 24 pin mobo connector in order to turn the second psu on.
rather than bother wiring in a new switch or a relay (and paying for same), would i be ok to splice these into the wires that come from the case switch to the power-on pins on the mobo? Would i be right in thinking this would work? seeing as you can start an atx mobo by shorting the pins with a screwdriver, i assume all the case switch does is short them in a more elegant manner?
With this problem solved, am i best using the second psu for the gfx card, and leave everything else alone?
thanks in advance!
TG
tl:dr - i want to do something ill-advised with power supplies. i could die without your sage advice!
thanks in advance!
TG
