Using Tap water to flush out rad??
18 Jul 2009
I have a few thermochill pa120.4's. They have water based flux. I was considering to just use hot tap water for the flush process and then just rinse it with distilled.
Any thoughts on this? The tap water would be max 2 hours in each rad an will be rinsed anyway. Is this safe ?
I always flush my rads with boiled tap water but I live in a soft water area & lime scale is not a problem.
Use water that is just about to boil, fill the rad & give it a shake. Remember the rad will get hot.
Tip the water out after 10 mins & repeat a few times.
On the final rinse, flush with distilled water.
Fit & enjoy
